c axis head Programing
rs8STG7
rs8STG7
Community Visitor
Community Visitor
Hi i am new to 4th axis manufacturing and just bought a new cnc machine with 4th axis which has the spindle that rotates from -90 to 90 degrees (C-Axis). the machine uses SYNTEC System. can anyone help me or tell me if there is a tutorial video which explains how to program it and post the G-code. mainly 4th axis will be used so i can place a wood door and cut for hinges and lock.
hyperbolicindustries
Are you sure that is called a C axis? Normally that would be called a B axis.
rs8STG7
Community Visitor
Community Visitor
yes because the machine display only has X Y Z and C and when moving the machine manually the 'C' changes value
thaont.cnc
