Spot Drill - Lead In and Lead Out Feed Rates
Message 1 of 9
Hi Guys
I noticed that the latest fusion update contains a fix for the Spot Drill tool that I reported in this post: http://forums.autodesk.com/t5/computer-aided-machining-cam/please-help-chamfer-bug/m-p/6821364#M2361...
Here is Fusions release notes on the latest update advising that this has now been fixed:  http://www.autodesk.com/products/fusion-360/blog/february-13-2017-update-whats-new/
Well, unless I am missing something I still cannot see a Lead-In and Lead-Out Feed Rate for Spot Drill even when creating a new Spot Drill tool......... (See Screen Grabs)
Could someone kindly enlighten me.
Regards
Grant
Replies (8)
Message 2 of 9
Steinwerks
My apologies.
Investigating, will edit soon.
Edit:
Looks like the fix is to link Lead feedrates to the Cutting feedrate:
If you change the Cutting Feedrate in the Edit and Compare dialogue you can watch the Lead feeds change to match.
Edit 2:
I agree this does not match what is stated on the Update blog.
@keqingsong Is this the intended long term fix that has not been applied yet, or can someone chime in here closer to the decision?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 9
Steinwerks on the case once again!  Cheers Dude!
G.
Message 4 of 9
Steinwerks
Haha thanks! Even though I am not a user of spot drills as chamfer mills, I am REALLY sick of this (as I see it) bug! Smiley LOL
Neal Stein
Find me on:
Message 5 of 9
jason35A49
I have experienced this also, I occasionally use spur drills for doing light chamfers on plastics and aluminum, was quick and easy now I get a feed rate of zero if I try to chamfer with the tool, not a big deal, just call up a chamfer tool with the same tool number and it's fine, just forget to sometimes and go to run a program and get illegal feed number, doh!
Message 6 of 9
Steinwerks
@jason35A49
This should be "fixed" now actually as of the update yesterday. It should pick up whatever you've got the feedrate set at in the toolpath and pass it off to the lead feedrates.
Neal Stein
Find me on:
Message 7 of 9
jason35A49
Strange, I had this issue just this afternoon, perhaps it hadn't updated on my end just then.
Message 8 of 9
al.whatmough
This was a "hot fix" not a complete fix.
The hot fix simply uses the cutting feedrate for the lead-in Lead out so that you don't get a feedrate of zero in your posted code.
We still have open work to add lead-in lead-out values for these tool types.
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Message 9 of 9
Cheers for the explanation Al.  Tested this today and all good.
I guess the image in Fusions release notes was just for reference purposes.....  I assumed that there were supposed to be Lead-In and Lead-Out fields.  DOH!
G.
