Sinumerik 810T Post Processor
kanpowersports
kanpowersports
I have an old Emcoturn 340 which uses the Seimens Sinumerik 810T control.
There is a generic 840 post that looks close (haven't tried it yet).
But the threading, drilling, and similar cycles do not work.  It'll generate a post that APPEARS close for simple geometry turning.
The 810 uses the infamous R paramters for the background details needed to complete these cycles.
(I do have an old operating manual, and make a bob-cad post work fine {what a headache!}).
Doing some searching here seems futile for this dinosaur.
Is there anybody out there that could help a programming inept person getting the 840 generic post processor modified to support these R parameters??
Thanks in advance.
Here's an example for threading in Bobcad:
2001. Program Block 1. thread lines
PI = 3.141592653589793
R20=LATHE_GetThreadLead()
R21=LATHE_GetProfileStartX() * 2
R22=LATHE_GetProfileStartZ()
R23=LATHE_GetFinishNumberOfCuts()
ORIENT = LATHE_GetToolOrientation()
If ORIENT = 3 OR ORIENT = 4 Then
R24STR = "+"&Round(tan(LATHE_GetAngleIn() * PI / 180) * R20 / 2, 5)
Else
R24STR = "-"&Round(tan(LATHE_GetAngleIn() * PI / 180) * R20 / 2, 5)
End If
R25 = LATHE_GetThreadLastCut()
R29 = LATHE_GetAngleIn() / 2
R31 = LATHE_GetProfileStartX() * 2
R32 = LATHE_GetThreadZ2()
CALL LATHE_ProcessPostLine(" n,'R20="&Round(R20, 5)&"','R21="&Round(R21 , 5)&"','R22="&Round(R22, 5)&"','R23="&R23&"','R24="&R24STR&"'")
CALL LATHE_ProcessPostLine(" n,'R25="&Round(R25,5)&"','R26=0','R27=0','R28="&R23&"','R29="&R29&"','R31="&Round(R31 , 5)&"','R32="&Round(R32,5)&"'")
CALL LATHE_ProcessPostLine(" n,'L97','P1'")
Here's an example for L97 Threading;
L97 Thread Cutting Cycle Parameters
R20 – Thread pitch.
R21 – Start point of the thread in X-axis.
R22 – Start point of the thread in Z-axis.
R23 – Number of idle cuts (idle passes).
R24 – Thread depth (positive value = inside thread, negative value = outside thread).
R25 – Finishing allowance.
R26 – Run-in path.
R27 – Run-out path.
R28 – Number of roughing cuts.
R29 – Infeed angle (half flank angle).
R31 – End point of the thread in X-axis.
R32 – End point of the thread in Z-axis.
kanpowersports
I went back and tried to re-post the turn operation with the 840d post, and it errors on opening. Smiley Sad
So, now I'm totally confused
kanpowersports
Ok!
I'm wondering who/if anyone has any experience or drive to help out here.  So far, for me, there's nothing but crickets chirping in the distance.  Smiley Frustrated
My OWN progress to date;
I've taken the Siemens general turning post and corrected the title block and program format. (Success!) and I am able to write out to my machine.  Hooray!!
Now; on to the fun stuff (As mentioned above);
The Cycles:  They are not working for my set-up
drilling won't post without error.
Tapping  also not working
Tool Change cycle ..... ETC.
I have the 810T platform.  It uses  R parameters prior to calling up the cycle which IS NOT cycle81 --(deep drilling) for example.  It is in fact listed as " L98"  for my machine.
My machining cycles are as follows:
L91/L92 Return cycles for tool change
L95 cutting cycle
L95 Cutting cycle (Roughing Parallel to Axis)
L98 Deep-Hole Boring cycle
In Comparison the post has these cycles as:
L91/L92 tool change = Not found-I may have to create a sub-routine for this and lock it in the machine.
L95 = Cutting cycles (I'm not sure about the value here as it seems general turning is posting, and fusion handles the toolpath options well).
L98  = Cycle 83 (chip breaking) in the post
(I didn't notice a cycle for thread turning, relevant to L97 threading, mentioned above.)
In the post; the R parameters I need, seem to be defined as RTP, RFP, SDIS, DP.... etc.
(example from the post). Under the drilling cycle type-
N1020           switch  (cycleType)  {
                         case "drilling":
                             writeBlock(
                                   "CYCLE81 ("  +  zFormat.format (RTP)  +   .............................................
.......I didn't want to try re-assigning these to what I would think should reflect the 810T's R values, for accessing the  options chosen, while working in the Cam.
I have the information assigning the R parameters in each cycle, from the Sinumerik book. However; I don't know how to modify this existing post to reflect R values from the act of choosing options in the cam side.
I am in great hopes of someone 'stepping up' here and at least offering me some guidance to start to check things out.
Again, Thanks for any help offered!!
Smiley WinkSmiley WinkSmiley Wink
