Simulate machine movement (tool path) between operations
mitchmod
Observer Observer
mitchmod
Observer
Observer
When simulating my setup with a 5-axis milling machine, the simulation includes the tool path for each operation. I want to also see the tool path between operations. Is there a way to see how the machine moves when transitioning from one operation to the next? Thanks.
a.laasW8M6T
Not currently unfortunately, but it will come eventually.
For me with a 4th axis its not too big of a deal, Machine retracts in Z then rotates.
But yea for a 5 axis it would be nice to see what's going on, Luckily(Or maybe not haha) Fusion does not do any fancy 5 axis linking moves
Andrew Laas
Senior Machinist, Scott Automation
DarthBane55
Interesting that it can't do this...  I'm almost sure that I read in a thread in early days of Fusion machine simulation that it would simulate g-code.  The fact that it cannot do this is pretty solid proof that it does NOT simulate g-code I'd say, therefore it is more to be used as a reference only, you still can have a surprise when you put that code in your machine.  Vericut or NCSimul is still the way to go!
a.laasW8M6T
Currently it simulates using the post processor, so ALMOST using the code.
Not as bad as just using straight toolpath data.
With Autodesk's Acquisition of Camplete a while back one would assume they will be adding some of that much more advanced simulation into Fusion but who knows haha
Andrew Laas
