Message 1 of 8
Shoulder collides with stock. No collision warning. Invalid spiral length in simulation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Incorrect simulation behavior detected in the community.
When using a cutter with a 10 mm long flute, 30 mm shoulder length, if you go to a depth of 20 - there is no collision warning.
The shoulder length is part of the tool shank, it cannot cut.
It should only be used as the maximum depth of cut, and show a stock collision error like the shank does.
But now the simulation uses the shoulder length as the flute length.
It is not right.
Yes, using multiple depth will warn you that the flute is not long enough, but the simulation will not show this ...
