Shift + Tab not working as expected
PinnacleMachine
PinnacleMachine
After this morning's update I'm noticing that Shift+Tab does not function as it used to, particularly in the feed rate and spindle speed fields - to tab backwards through fields. Instead it brings up a drop down menu. I find this extremely irritating as I don't like having to mouse through the fields - after 25 years it's hard to change certain behaviors.
jeff.pek
Hi -
Thanks for reporting. We're aware of this as well. It happens to occur more frequently within the Manufacture space, as a side effect of introducing auto-completion for expressions. It can also happen in other areas, depending on the parameters that are associated with a particular input field.
Jeff
