Setting X-Y Zero offset from stock
Hi, I'm a new user of Fusion 360.  I'm trying to figure out how to set an X-Y zero offset from my stock.  Currently I use VisualMill for my CAM needs.  It allows me to select a point on the box stock just like Fusion 360 but I can also input a coordinate to offset the stock from zero.  Is there a way to do this in Fusion 360?
HughesTooling
One way you could do this is to have a sketch with a point with the offset you want.
Then snap to that in your setup.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff.walters
There are some great training videos on YouTube that will help you get started, as well as some step by step tutorials under the help.
https://www.youtube.com/watch?v=6FzbZNhey2w&list=PLmA_xUT-8UlK9rndthGGHsjjnZtPO8XRV
Jeff Walters
Senior Support Engineer, CAM
Thanks Mark, That worked great.
