setting work offset and tool lengths
jacolouwrens_jl
Message 1 of 9
jacolouwrens_jl
Hi everyone. I'm new to CNC machining and got started using fusion 360 for toolpaths. I need some help setting up the tool lengths and work offset. When I set up my tool lengths and work offset my simulation gets thrown all over the place. Its hard to explain but when I set my home position to zero and my tool offsets to zero everything works fine.
I use a siemens 808D controller on a CKE 6150Z lathe with the generic siemens turning post.
Replies (8)
Message 2 of 9
jacolouwrens_jl
Almost forgot. here is the setup.
https://a360.co/4fPzRyU
Message 3 of 9
2469971149
Could you provide me with some images that show the simulation situation so that I can better assist you?
Message 4 of 9
jacolouwrens_jl
looks something like this on the controller. this isn't the same workpiece tho its just to give you an idea
Message 5 of 9
jacolouwrens_jl
funny thing is I just manually typed in the code and everything ran smoothly.
Message 6 of 9
jacolouwrens_jl
here's another picture. it almost looks like the home position flips around and becomes negative
Message 7 of 9
jacolouwrens_jl
sorry didn't directly reply to you but here's the pictures
Message 8 of 9
jacolouwrens_jl
In the first post there is a drilling cycle so I had to put in a G17 manually for it to work but even without a drilling cycle the simulation still looks the same
Message 9 of 9
jacolouwrens_jl
here is the Gcode
