SCM POST MODIFICATION
Hello all,
I am having some difficulty utilizing a generic SCM post I am using from the fusion post library. I am trying to post projects created in fusion 360 to an SCM Accord 30 FX-M CNC Router using the post  "scm-cps - Generic SCM Prisma 110"
I have attached a pdf of the code created in an scm program I usually use called Maestro with its native post (similar coding to Xilog Plus) and a comparison of code created in fuson 360 using the generic scm post
I made three header modifications to the generic scm post before using it:
I changed units from MM to IN
I changed to field from A to AB
I changed the tooling file from DEF to DEF_MATRIX which is the tooling file associated with the machine I am using.
The sample program is very simple consisting of a 3/4" wide by 24" long by 1/4" deep slot machined in two lateral passes using a 5/8" dia. router.
The Maestro program runs fine (as expected), but when I run the program created and posted by fusion 360, the cnc picks up the 5/8" dia router bit, travels to the first machining operation (X=24 Y=4.688 Z-2.325) and then just dwells there with the spindle running at clearance height.
I realize that I must be missing header information but don't know how to proceed with adding it.
Any help would be greatly appreciated as I am not comfortable using Java Script for any in depth post modifications.
Thanks in advance,
Hi I am a brand new user of Fusion so not sure how much I can help but I have successfully used Fusion to run my scm Record 5 axis machine with the same post processor, I use xilog plus. Have you tried running the .xxl file through the Winxiso app to convert it to a .pgm? You should find Winxiso in the bin folder in the program folder containing Xilog if you are using windows.
mehulGYL6Z
Hi Stephen,
I just tried using the generic post file in Fusion 360. I have a Record 110 Al Prisma, but I had an issue in Xilog that said "The tooling file set is not in the main directory". I am new to this so may be an easy fix I don't know about.
Mehul
Hi Mehul
I am not certain what your problem might be, we have had our own post
written for Xilog now , please contact [email protected]
for details
james.smithHCBT6
Good afternoon @Anonymous
Did you manage to sort you post processer out?
we have an Accord fx20 and i have created a post for it and was wondering if i could skim over yours to see if there is anything else i should/ could put in it.
also what did you end up using for the saw blade?
JonasDM46
Hi sir,
You have a working post processor ?
Willing to share the post with me ? I'm running a SCM Morbidelli M600.
Kind regards,
Jonas
