Router Machining Strategy - Complex Cut
krummeck
Message 1 of 13
krummeck
Good Evening
I am needing a strategy to cut an end of a piece smaller in the x, y and z dimension. I will attach a screen grab of the end, and if you could advise on what other files you require to solve this cut. Please Advise
Kind Regards
Warren Krummeck
Replies (12)
Message 2 of 13
Marco.Takx
Hi @krummeck,
Can you share your model so one of us can take a look at it?
From the picture I should say depending on the size:
  1. 3D Adaptive Roughing everything
  2. 2D Contour outside finishing
  3. face top
  4. Pocket or contour with multiple passes for Facing lower level.
  5. chamfering
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 13
krummeck
Hi There
I would love to share the model... what do I need to do, is it a export as, or a saved copy, what do you need?
Warren
Message 4 of 13
Marco.Takx
Hi @krummeck,
You can export it to a local drive and upload it to this forum.
So one of us can take a look at it.
Marco Takx
Message 5 of 13
seth.madore
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
If the file contains linked component, the links must be broken. If the file cannot be shared due to privacy concerns, you can email me the file: seth dot madore at autodesk dot com
Seth Madore
Message 6 of 13
krummeck
Here is the .step file
Message 7 of 13
krummeck
STEP didn't go through here is the other format
Message 8 of 13
Marco.Takx
Hi @krummeck ,
You forgot to attach the STEP file Smiley Happy
Marco Takx
Message 9 of 13
krummeck
yes I am battling to attach it, added the 3d file in the next post
Message 10 of 13
seth.madore
Warren,
What exactly are you trying to machine on this part? Your original post says "Make smaller in the x,y,z dimensions"
How so? How much? Is this a permanent change to the part or just a single change?
Seth Madore
Message 11 of 13
krummeck
Hi There
The long thin plank has ends that are thinner and narrower than the rest. It is these ends that I need a strategy for, not knowing if it should be a 3d cut, various 2d cuts. The rest of the part I will cut with a 2d contour.
I hope this makes sense. I did post a pic of the end/s needing cutting. It is 18mm plywood (17.7mm accurately) so no surfacing or any of that needed, just cut the shape out and follow a strategy to cut those ends.
Kind Regards
Warren
Message 12 of 13
seth.madore
Yes, I saw the picture, but I was puzzled by your "smaller in x,y,z" comment. That implied that you wanted to make it smaller then it already was
Here are some of my thoughts on how I would do it:
Seth Madore
Message 13 of 13
krummeck
Wow Seth, that is phenomenal
wrt The dogbones, the end slips into the slot on the top of those 'sides', so what I have done is to make that cut run under where the sides will be. Wedges will be taped into the groove cut and the rounded edges I have left can be replicated onto the wedges, so they will stay. I will need to chisel out the 2 rounded corners on the shoulders that the sides push up against, this I will do.
The magical ALT key, when I touched that bottom edge to get that piece to cut, the whole profile was selected. Right there the strategy fell into the water and drowned.
Thank you once again for the advice, video and all the solutions, I really do appreciate this. I will now go through that video piece at a time and replicate you movements for each step.
Kind Regards
Warren Krummeck
PS I will post pics of that cut and the stand when I have made it.
