Rotary Toolpath leaves stock.
Linus_Follinger
Linus_Follinger
i can´t get the rotary toolpath to go all the way in. (finnish pass).
it leaves a lot och stock depending on my stepover.
is this not possiable to machine a little staircase like this with rotary?
its not shown in the video but i can machine the OD without trouble.
LibertyMachine
I would expect that to work as it is. Try setting it to "Circular Passes" instead.
On the other hand, for a part such as this, I'd likely use 2D Contour > Wrapped, but that would also necessitate a model split and some voodoo.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
seth.madore
whoops, that's me above.
Seth Madore
Linus_Follinger
Sadly circular leaves an even layer and only finish a little portion.
But thanks for the Fast answer @seth.madore  !!
ill try the countour- wrap toolpath with split body
im just trying to get familiar with rotary basics.
for now ill run the part in the 3 - axis
