- Mute
- Permalink
- Report
I'm using a 4 axis machine, I usually carve wood with it. Here's my workflow: two adaptive paths(3d) using a 3-6mm flat tool for the roughing stage, one rotary parallel path for the details.
The accidents happen at the beginning of the rotary path, it always pluges into the wood too fast, and my tool here is always a very fragile v shape tool, usually 0.1-0.3mm tip with tip angle of 20-30 degrees. as a result several of my tools broke.
I even added a special path between roughing and detailing paths to cut some space around the position where the first cut happens in the detailing path, however it can't always clean that area good enough to let the v tool do the first plunge safely.
what's your strategy for this kind of work?
