Reverse Countersink in Blind Slot
MFZTM6E
New Member New Member
MFZTM6E
New Member
New Member
Im new to Fusion and Im struggling to programme a reverse countersink in to a blind 'keyhole' slot.
i want to feed the cutter in at the large end of the key, move along and create the countersink by raising the cutter, then drop down and move back to large end to exit slot.
Help would be nice please
seth.madore
Can you share a sample file that has this feature?
I suspect it's going to be challenging to program. We might be able to accomplish this with the Trace toolpath, but that's only a guess...
Seth Madore
programming2C78B
If you mean an underside chamfer (countersink implies its a round feature) then Trace is the only way. Been there!
Please click "Accept Solution" if what I wrote solved your issue!
MFZTM6E
New Member
New Member
the feature highlighted as under the key slot is a round countersink, the slot is a blind slot.
got a feeling im going to have to manually prog it?
programming2C78B
Simply sketch this on the midplane of your feature, then use a Pattern function to repeat it.
