Retract height question
JJackrabbit
JJackrabbit
Hi
I have a bit of a strange problem and can't find out why it happens.
My tools are in the Fusion360 tool library and the tool length is in the tool length table of my CNC controller software (linuxcnc).
So far everything is working fine.
I machine a part that has a height of 20mm.
After machining the tolerances are spot on. 20mm=20mm
But when the tool retracts it sometimes hits the wall of the part.
Z should go up, once it's up it should move in X and Y direction to the next spot.
But instead it goes up and in the last part of the Z movement it already starts to move in the X and Y direction where it sometimes hits the part with the tip of the endmill/drill.
Could this be Fusion360 related?
I can increase the retract height by a couple of mm, but that's a workaround.
LibertyMachine
To better answer your question, could you share your model?
File > Export > Save to local folder. Return to thread and attach the .f3d
It's likely a user setting, not a Fusion issue
What is the machine and control?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
JJackrabbit
added the f3d
LibertyMachine
Seth Madore
JJackrabbit
I use a MESA card with LinuxCNC and a Tormach PCNC1100 clone
etfrench
I've had the same thing happen to me with broken tool bit as a result.  There are two settings that may affect this:
  1. On the Linking tab set the High Feedrate Mode to 'Preserve Radial Movement'
  2. Also on the Linking tab, check the 'Perpendicular' checkbox
ETFrench
JJackrabbit
Thanks, I will check those settings
