required help for manufacturing cam operations
shivamrajputwork
shivamrajputwork
I am facing difficulties in generating smooth tool path to reduce the machining time issue i am facing is tool path is generated but it takes lot of time the tool path is not optimized as per my needs.
kindly help in that. it will be very helpful for your kind support.
i will share the step file for the reference once i get the reply.
Thank you
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
shivamrajputwork
should i share step file or fusion 360 file??? step file will be enough let me know
seth.madore
Always share the Fusion file, as it gives us a sense of what toolpaths you've tried, how you're defining the Setup and Stock, etc etc
Seth Madore
shivamrajputwork
hello please find the attached file as requested
and let me know the solution
all i want is how to optimised the toolpath to reduce the machining time
