Remove G18 Post Doosan Puma Turning 2ax
serkan.yamanZ5DYG
serkan.yamanZ5DYG
Hello Friends;
Im looking for the way of remove G18 from my post, I don't understand why there is g18 on 2 axis lathe posts can anyone help?
O9001
G98 G18
G21
G50 S1500
G53 G0 X0. Z0.
(PROFILE FINISHING2)
T0101
G54
M8
G99
G97 S600 M3
G0 X65.012 Z5.
G0 Z-7.4
X23.063
G1 X7.211 F0.1
Z-8.
X18.7
G18 G3 X19.5 Z-8.4 R0.4
G1 Z-23.
X44.212
G3 X45.012 Z-23.4 R0.4
G1 X49.012
G0 X65.012
Z5.
M9
G53 G0 X0. Z0.
M30
serge.quiblier
Hello @serkan.yamanZ5DYG
G18 is indicative of the plane used for arc interpolation.
It should not cause issue.
But if you can't support seeing it, simply edit the post.
Then inside the code, start with the onOpen function:
  writeBlock(conditional(getProperty("type") != "A", gAbsIncModal.format(90)), formatFeedMode(FEED_PER_MINUTE), gPlaneModal.format(18));
must be changed to:
  writeBlock(conditional(getProperty("type") != "A", gAbsIncModal.format(90)), formatFeedMode(FEED_PER_MINUTE));
You can then do the same thing in the onLinear, and onCicular function, removing the
where is appears.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
