Rectangular hole
Rectangular hole
leoE4H8W
Message 1 of 9
Rectangular hole
leoE4H8W
I can's get the bottom hole cut, the pockets are good.Screenshot 2024-06-26 125859.png
Replies (8)
Message 2 of 9
programming2C78B
We will need...some information. You already had a thread open about this.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 9
leoE4H8W
I still haven't gotten it right, please explane again
Message 4 of 9
leoE4H8W
Here's the file
Message 5 of 9
leoE4H8W
Here;s the file
Message 6 of 9
programming2C78B
You are using 2d adaptive with the wrong geometry selected, and the depth is too shallow to include the pocket itself.
Adaptive is usually done with a much larger DOC as well, usually 2x the tool diameter.
It's also .328 wide and your tool is .313, so all leads and stock adjustments must equal less then .015". Use 2D contour with ramp.
Message 7 of 9
leoE4H8W
The x is the pocket and the blue in the hole i want to cut.Screenshot 2024-06-26 125859.png
Message 8 of 9
programming2C78B
yes, im aware of that. None of that changes what I said.
Message 9 of 9
leoE4H8W
I got it, but this is what I get now.
