Recent update blew up post settings
rhetteshleman
Message 1 of 18
rhetteshleman
Apparently there was an update Sunday and now my post file is missing. I checked an older file and I see which post file it is but it's not in my local or cloud anymore.
How do you guys that do this for a living use this software with confidence? Almost 1k a year and it's getting worse.
Error:
Code page changed to '1252  (ANSI - Latin I)'
Start time: Wednesday, March 13, 2024 8:17:16 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.6050.1
Configuration path: C:/Users/Rhett/AppData/Local/Autodesk/Autodesk Fusion 360/ZNRBJKL5QHB5/W.login/M/D20200731320125306/CAMPosts/uccncv5.cps
Security level: 1000
Include paths: C:/Users/Rhett/AppData/Local/Autodesk/Autodesk Fusion 360/ZNRBJKL5QHB5/W.login/M/D20200731320125306/CAMPosts
Configuration modification date: Sunday, March 10, 2024 7:04:09 PM
Output path: C:\Users\Rhett\Desktop\GCode\aaaaaa\1001.nc
Checksum of intermediate NC data: eded4dc4c526c25a6e987575d2e84be2
Checksum of configuration: d0718d7e7e9acfb272a3a18e3cdf9613
Legal: Copyright (C) 2012-2023 by Autodesk, Inc.
Generated by: Fusion CAM 2.0.18477
Error: uncaught exception: Invalid axis vector for axis construction.
Failed while processing onOpen().
Error: Failed to invoke function 'onOpen'.
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, March 13, 2024 8:17:16 PM
Post processing failed.
Replies (17)
Message 2 of 18
seth.madore
That's not an expected result, by any means. Are you using a Machine Configuration in your file, by chance? Do you have any files to share that will help us to reproduce the error? Please share them here if you do!
Seth Madore
Message 3 of 18
spencerlull
Did the update, and now the software will not post. Very frustrating when you are trying to get some work done. Any idea how to fix this nonsense?
Michael
Message 4 of 18
a.laasW8M6T
Hi
Can you provide specifics like, Which post you are using and what error messages you are getting?
Andrew Laas
Senior Machinist, Scott Automation
Message 5 of 18
spencerlull
Information: Configuration: OpenBuilds CNC : GRBL/BlackBox
Information: Vendor: OpenBuilds
Information: Posting intermediate data to 'C:\Users\Spencer\Desktop\G-Code\1001.gcode'
Information: Total number of warnings: 2
Error: Failed to post process. See below for details.
Start time: Sunday, March 31, 2024 9:26:15 PM
Warning: (OpenbuildsFusion360PostGrbl.cps:276) Setting read-only property "power" on object of type "PostProcessor". This will have no effect.
Post processor engine: 5.131.1
Configuration path: C:/Users/Spencer/AppData/Local/Autodesk/Autodesk Fusion 360/WHX28LQUMGAHEDHF/W.login/M/D20220422519258231/CAMPosts/OpenbuildsFusion360PostGrbl.cps
Include paths: C:/Users/Spencer/AppData/Local/Autodesk/Autodesk Fusion 360/WHX28LQUMGAHEDHF/W.login/M/D20220422519258231/CAMPosts
Configuration modification date: Saturday, April 23, 2022 6:50:24 PM
Output path: C:\Users\Spencer\Desktop\G-Code\1001.gcode
Checksum of intermediate NC data: 9d4fa4a40a8df3faf31c9051e331e236
Checksum of configuration: 04da79ca5f8aa4c42ef5a167d5436a8f
Generated by: Fusion CAM 2.0.18719
Warning: Invalid Work Coordinate System. Select WCS 1..6 in SETUP:PostProcess tab. Selecting default WCS1/G54
Error: Failed to invoke method of class 'PostProcessor'.
Error at line: 841 (OpenbuildsFusion360PostGrbl.cps)
Error in operation: 'BridgeBottom_Parralel'
Failed while processing onSection() for record 533.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Stop time: Sunday, March 31, 2024 9:26:15 PM
Message 6 of 18
spencerlull
Error log has been added.
Message 7 of 18
a.laasW8M6T
Hi
There appears to be a problem with the Open builds post, I don't know enough about JavaScript to figure out what the issue is.
being that this is a Third Party post it may pay to contact the post developers for assistance.
in the short term you could use the Fusion supplied grbl post, that one still works fine.
Andrew Laas
Message 8 of 18
spencerlull
Strange, it has worked fine for 2 years before this update. How do I find the Fusion GRBL post?
Message 9 of 18
a.laasW8M6T
(view in My Videos)
Andrew Laas
Message 10 of 18
spencerlull
Found and loaded the Fusion GRBL file, but when attempting to run, it triggers my z axis before it has a chance to start.
What a frustrating update. I wish I never clicked it.
Message 11 of 18
spencerlull
I changed a parameter to "clearance height" and now it looks like there is some conversion factor messing up the tool path when running on the machine.
Message 12 of 18
spencerlull
How do I change the generic post processor to inches?
Message 13 of 18
a.laasW8M6T
Andrew Laas
Message 14 of 18
spencerlull
Thanks!!!
Message 15 of 18
seth.madore
@spencerlull do you have the "Optional Feature > Use Upgraded Post Engine" option turned on?
Try turning it off and then using the post you're accustomed to use and see if the issue remains.
Seth Madore
Message 16 of 18
a.laasW8M6T
Hi Seth
I did try that option on and off and it fails the same both ways.
also fails to post in VS code with the extension with a timeout error
This post here:
https://github.com/OpenBuilds/OpenBuilds-Fusion360-Postprocessor/tree/master
Andrew Laas
Message 17 of 18
gymnyan-man
This post is a machine translation.
Sorry if it's hard to read.
I was using the same post and faced the same issue. I posted it on the Japanese forum,
but it hasn't really solved the problem.
Set the WCS offset in the setup settings.
Posting is now possible by setting the spindle rotation speed to 10,000 ~ 20,000 rpm(Makita router speed).
Up until now, you could post by simply ignoring the warning dialog when posting, but after the update, this will now fail.
I think there may have been some kind of update to the processing of posts that display dialogs, but I'm a baby so I don't know.
Message 18 of 18
a.laasW8M6T
Thank you for the information, it pointed me to the right direction to where the issue appears to come from.
This section:
   if (rpm < speeds[1])
      //alert("Warning", rpm + " rpm is below minimum spindle RPM of " + speeds[1] + " rpm in the " + op + " operation.");
      return 1;
   if (rpm > speeds[speeds.length - 1])
      //alert("Warning", rpm + " rpm is above maximum spindle RPM of " + speeds[speeds.length - 1] + " rpm in the " + op + " operation.");
      return (speeds.length - 1);
   var i;
   for (i = 1; i < (speeds.length - 1); i++)
      if ((rpm >= speeds[i]) && (rpm <= speeds[i + 1]))
         return (((rpm - speeds[i]) / (speeds[i + 1] - speeds[i])) + i).toFixed(1);
   //alert("Error", "Error in calculating router speed dial.");
  // error("Fatal Error calculating router speed dial.");
   return 0;
It appears "alert" and "error" are not valid functions and cause the problem
I have commented them out as they appear to have been in the other parts of the post.
Please find the attached version that works, albeit without the error checking for spindle speed.
The alert function is still present in other parts of the post however and may still cause issues, the post developer will need to rectify these in their next release
Andrew Laas
