Ramp and Vertical Surfaces
vid.kok
vid.kok
My question is about Ramp operation. A section of the part doesn't have a tilt angle so the toolpath won't go fully around the part. Is it even possible to machine vertical surfaces with Ramp?
With tilt angle:
Without tilt angle:
I attached the part.
Tianq
@vid.kok,
I removed the selections of Machining Boundary in that operation and the toolpath generated is shown as below.
Dave (Qing) Tian
HughesTooling
You might see this in a design where you want to use boundaries, all you needed to do was add a small additional offset, you had tool outside but you need a bit more like 0.1mm.
Mark
Mark Hughes
Owner, Hughes Tooling
vid.kok
@HughesTooling, that worked perfectly! Thank you!
