Programming for wirecut (Wire-EDM) machines
pramodQ4FRF
Message 1 of 18
pramodQ4FRF
Is programming for wirecut (Wire-EDM) machines possible from fusion 360?
Replies (17)
Message 2 of 18
seth.madore
Not natively, no. There are some users who have opted to use 2D Contour, define an endmill the same size as the wire, and hack a post processor to give them decent code. Note, that this does not allow for 4 axis motion, it will just be 2D. We get requests for wire EDM quite frequently, but as of yet, we haven't added native functionality into Fusion.
Seth Madore
Message 3 of 18
MattWynn
2D Profile has been used for years to create toolpath for 2D edm.  2D Profile (usually for Plasma, laser, waterjet) is similar to 2D Contour, but without settings used for milling tools.
I've heard that swarf operation might work for 4 axis edm, but that would requite quite a bit of hacking and I don't think has been done.
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
Message 4 of 18
pramodQ4FRF
There should be proper workspace for "Wire-EDM programming".
Message 5 of 18
seth.madore
But....there isn't, and I don't believe there are any current plans to add one.
Seth Madore
Message 6 of 18
johnswetz1982
Also, though I cant find it now but I did see it in the past. Autodesk did have a EDM specific software along the lines of Power Mill, something like Power EDM, etc. I know they have an electrode module for Power Mill but not sure about wire. I am not sure they would be selling to undercut one of their own products.
Message 7 of 18
pramodQ4FRF
If wire EDM workspace is added Fusion 360 can be used as single product which can provide end to end solution for die mold industry.
Message 8 of 18
MattWynn
@pramodQ4FRF Why do you say 'EDM workspace'?
IF we were to add support for EDM, it would start with a new operation in the manufacture workspace.
What is needed beyond a new operation?
Matt Wynn
Message 9 of 18
Mattxer
I don't see a need for a whole workspace. Something similar to how waterjet/plasma is with a 2D and Swarf-like contour toolpaths. Params for Nozzle heights and wire diameter, a few manual nc's for tank and flushing codes and that pretty much covers it lol. I really wish there was a way to create custom toolpaths via the API but it does not appear to be possible unfortunately.
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Message 10 of 18
eloymBGBQP
Observer
Observer
Any updates on Autodesk products that support wirecut EDM with 4th axis on Fanuc machines in 2023?
Message 11 of 18
HughesTooling
@eloymBGBQP Autodesk's FeatureCAM does wire erosion.
https://help.autodesk.com/view/FCAM/2024/ENU/?guid=GUID-6F18C0BC-15DB-4F34-AC0A-179E7E289EBE
Mark
Mark Hughes
Owner, Hughes Tooling
Message 12 of 18
fernanda_medina_aguirre
Share Wire EDM Feedback
I'm Fernanda, a Manufacturing specialist focused on the implementation of manufacturing solutions. At Autodesk we are always looking for ways to make our customers’ experience great.
We would love to hear your thoughts about Wire EDM.  Please respond to the following survey, which will help us to understand your current manufacturing needs. The survey should take 5 mins or less to complete.
Wire EDM survey link
We really appreciate your time. Your feedback helps make Autodesk even better.
Message 13 of 18
rockyN2JHF
Community Visitor
Community Visitor
Here it is; a year after the last post, and still no support for Wire EDM in Fusion.  Yet, Autodesk stripped FeatureCAM down as spare parts, and FeatureCAM had unmatched wire EDM capabilities 20 years ago.  Now, of course, FeatureCAM is unusable, due to being cloud-based as well; that may be the saddest part.
Message 14 of 18
Machiningsokiguess
We would really like this! How can we get this going again? We want multi axis functionality but if its only 2 axis to start. That would help a lot.
Message 15 of 18
a.laasW8M6T
Prosolids just released their Addin for Fusion for Wire EDM
https://www.prosolids.com/
Andrew Laas
Senior Machinist, Scott Automation
Message 16 of 18
emil_gerasimov
There is a WEDMPugin for Fusion: Pro solids Wire EDM which adds WEDM tabs in manufacture workspace.
Message 17 of 18
emil_gerasimov
Can this problem to be caused from the update of 27 september, where project hub supports new roles and permissions?
My acount has administrator level, but eveyone else in the hub have the same problem.
Message 18 of 18
Machiningsokiguess
I saw Prosolids but the price was a bit much at $2k per year. At that price why not go with esprit?
