Problems with C-axis machining using the Haas UMC750
haas1FD6Q9
haas1FD6Q9
Hello, I am planning to perform 2-axis planar machining on the top surface of the material.
Due to precision requirements, I would like to perform hole machining by rotating only the C-axis without moving the X and Y axes
Is there a separate function to rotate only the C-axis, similar to a lathe? Or would I need to modify the post-processor
a.laasW8M6T
Hi
You can use the manual NC action command "USEPOLARMODE" with the HAAS postprocessor to get a toolpath the moves only in X(X+ to X-) and rotates the C axis.
You need to put the Manual NC before each toolpath you want to be Polar
(view in My Videos)
I think rather than using the Scallop toolpath, it would be better to use the Scallop in the Steep and shallow toolpath as this has a Spiral option with will give a continuous spiral inwards
You could also use the Spiral toolpath but steep and shallow is better.
See attached
Andrew Laas
Senior Machinist, Scott Automation
haas1FD6Q9
Thank you. I will check this right away when I arrive at work tomorrow
haas1FD6Q9
Thank you. I was able to obtain accurate NC data. Is there a separate manual book where I can find commands like this?
a.laasW8M6T
Hi
The Action Commands are often specific to the Post processor, I think the Haas one is the only MILLING post that has the polar mode option.
all the Turn/Mill posts have something similar.
Here is a link to the Fusion Post Guide that has some more information
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
Manual NC reference:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID895129FD-6548-414D-8B31-EDBCC5EF4439
Andrew Laas
