Problem with Wrapped Toolpath Axis Substitution.
Message 1 of 29
I am trying to machine a four start helix . I have tried so many different ways but always end up with the following warning: Dependency  on operation set up2 is ignored because it doesn't use axis substitution. Toolpaths are generated and simulation plays OK but so far I have had no success in getting any g-code when I attempt to Post Process
Accepted solutions (3)
Replies (28)
Message 21 of 29
I posted the file using Tormach PP from installed library, attached in zip folder.
Message 22 of 29
husamcivil
Hi Vick,
thanks for that at least I should be able to use it to get my
part made.
Bob Rodgerson
Message 23 of 29
Except for one detail, after running programmed tool path, you need to cut taper from vertical walls by using taper end mill, see why further back in one of my posts.
Message 24 of 29
husamcivil
Hi Vick,
I did notice that in your previous posts. Shouldn't be too much
of a problem. Thanks for all the help.
Message 25 of 29
dhanushsansa
Observer
Observer
please can anyone solve this. It comes warning error axis substitution error.
Message 26 of 29
You are not showing any tool paths, you can use 2D contour with passes and depth cuts to rough out stock and finish shaft leaving some stock.
After that sketch 4 lines, 90 degrees apart in XY plane and use them as tool orientation.
Using ball end mill and 3D contour or Scallop, machine each of the 4 sections so that tool paths overlap by small value.
Assuming 4th axis work, each line used as tool orientation will index A axis, you need 4 operations, after programming first, duplicate operation 3 times, change tool orientation for each one and regenerate operation.
All sharp corners will have fillet and some areas will not be fully accessible.
Message 27 of 29
dhanushsansa
Observer
Observer
I tried but it does not work. I'm new to 4 axis milling.Can you solve this to me
Message 28 of 29
dhanushsansa
Observer
Observer
Message 29 of 29
Well, there is a learning curve, try harder and follow provided training materials to acquire basic skills before tackling complex projects.
If you search "4th axis" subject, you will find practical examples in other posts that will make it easier, here is a illustration of using tool orientation to index A axis for machining desired side of model.
