Problem with single pass thread turning
EccentricEngineer
EccentricEngineer
With the last update I have a problem with threading. Usually I'll cut in the thread with 4 or 5 passes, profile the threaded area to get rid of burs, then do another single pass with the threading tool. Well, now fusion is unable to create a toolpath if I select "1" as the number of step downs. It doesn't give an error, it just doesn't generate a tool path.
Is there a fix for this, or a way around this other than hand editing the NC code?
seth.madore
This is a known issue that we've resolved internally. Look to a future update to see the expected behavior!
Seth Madore
seth.madore
My apologies, I've been informed that a hotfix went out a couple of days ago. If you've paused updates for the time being, I encourage you to consume this hotfix and that issue will be no more!
Seth Madore
