Problem with bezel cut direction
subteblu
subteblu
Hi all. I'm trying to make a bezel, I do not have a 45 ° tool. So I'll try to do it with a ball nose, it's a small job. I'm trying to make the tool move parallel and 90° descending from top to bottom, but the left bezel, even if it does it individually, cuts it from bottom to top. Any way to change it? I'm using Slope 45-90 ° and Touch Surface to try to do it individually in two operations, right and left bezel separately. Changing entry position has no effect. Thanks a lot.
Marco.Takx
Hi @subteblu,
Have you tried to use this setting?
You can also try to use the Flow operation.
If you can’t get it to work you can share your model so one of us can take a look at it?
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
seth.madore
Pass Direction. Set it to 180 (if it's already set to zero) and it will reverse direction
Seth Madore
subteblu
It was at 90 °, now I created two independent parallel strategies, one at 90 ° and another at 270 °and it is working. I thought I could do the two parts with one strategy. The other solution did not work.
It is a weak machine, I can not make descents at 0 and 180 at that depth, I need to go down by little horizontal steps
https://a360.co/2Enz1Zi
Thanks for the help!!
