Problem with B axis in TNC640
- Mute
- Permalink
- Report
Hello
I have a 5x machine with a rotating axle C and a tilting axis B on TNC640. When I generate in Fusion 360 indexed programs, the B axis always turns to plus. But I often have to generate a mirror prgogram, e.g. relative to YZ. Fusion then turns the axle +B instead of simply twisting the axis -B. In the attached picture you can see that the hole is far from the operator. It will be closer in the mirror part and it will cause a collision with the machine. I tried Cycl19 and Spatial Plane. The same effect +B. I use a postprocessor from the Fusion library. Maybe it's a problem of Fusion 360 himself. Maybe someone has an idea. Sorry for my english.
Regards
Jarek Ostrowski
