Problem turning contours into tool paths
tom
Message 1 of 8
tom
I am have a problem getting fusion to recognize the contour selected and turn them into to toolpaths.   This should be so simple!  Do I really need to sketch a tool path?  TomScreenshot 2021-09-17 113058.png
Replies (7)
Message 2 of 8
HughesTooling
As I requested in your other thread, can you share the design?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
tom
Message 4 of 8
HughesTooling
This seems to work OK for me. Looks like you selected the edge the same way in your image above or are you trying to do something different?
Mark
Mark Hughes
Message 5 of 8
tom
That solved it.....   I was doing the same thing accept I chose all the edges in the contour.  You chose the two parallel edges and the rest of the contour chose to fill in.   I am not sure this is a good thing.  The difference being on what edge you clicked first.
Message 6 of 8
tom
Are you sure this is not a glitch in the new software?
Message 7 of 8
tom
It had to do with my stock to leave   Is there a up level threshold for tool clearance that would effect the stock to leave?
I have a .250" end mill  an .3125" slot and was want to leave .010" per side for finish pass.....
Message 8 of 8
HughesTooling
With the stock to leave added you need to reduce the minimum cutting radius.
Mark Hughes
