Problem on cam
Problem on cam
nikoDJ4GQ
Problem on cam
nikoDJ4GQ
Hi there.
I'm trying to make a 2D pocket on the surface of this wood piece. Trying to get the logo appear and the rest black (i'm using some chronos wood panel, white on top, black inside). But NO way to get that thing done, as you can see the down right part always stays out of touch. It's like if it did not exist or something. I tried everything all day long and it takes half an hour for my macbookpro to calculate that. ANd every time, a quarter is missing. I tried with adaptive clearing, and same issue... Any ideas ? Thanks a lot for your help.
Niko
LibertyMachine
Could you share your file here?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
nikoDJ4GQ
sure ! thanks
randyT9V9C
Try 3D Pocket Clearing rather than 2D Pocketing. I used silhouette for the geometry. On the height tab use model top, as zero and for bottom use model top minus depth (-3 mm).
nikoDJ4GQ
Wow ! Thanks so much. It does work. And calculate is way faster, like waywayway faster !
Thanks again. I can now make that present for my friend's shop !
