problem in UGS sender with Fusion 2D contour toolpath
Im having a problem in UGS sender when using a 2D contour toolpath generated with Fusion 360.
When the toolpath contains arcs, my CNC controlled with UGS does straight lines instead of arcs.
The toolpath shows a red arc instead of a blue arc.
This doesn't occur when I generate a toolpath using other CAM operations from Fusion 360 like 2D trace.
Then the arc toolpath in UGS sender shows as a blue arc and everything is fine.
I need the 2D contour operation to generate tabs in my toolpath.
Any Ideas how to fix this problem? Im not sure if it's an Fusion 360 problem or a UGS sender problem. My CNC is able to do arcs in operations send by UGS sender but just not with this 2D contour operation.not working red arc from a 2D contour toolpath
working blue arc from a 2D trace toolpath
the toolpath I try to run with 2D contour operations with tabs integrated. not working
