problem in UGS sender with Fusion 2D contour toolpath
Message 1 of 11
Im having a problem in UGS sender when using a 2D contour toolpath generated with Fusion 360.
When the toolpath contains arcs, my CNC controlled with UGS does straight lines instead of arcs.
The toolpath shows a red arc instead of a blue arc.
This doesn't occur when I generate a toolpath using other CAM operations from Fusion 360 like 2D trace.
Then the arc toolpath in UGS sender shows as a blue arc and everything is fine.
I need the 2D contour operation to generate tabs in my toolpath.
Any Ideas how to fix this problem? Im not sure if it's an Fusion 360 problem or a UGS sender problem. My CNC is able to do arcs in operations send by UGS sender but just not with this 2D contour operation.
not working red arc from a 2D contour toolpathnot working red arc from a 2D contour toolpathworking blue arc from a 2D trace toolpathworking blue arc from a 2D trace toolpaththe toolpath I try to run with 2D contour operations with tabs integrated. not workingthe toolpath I try to run with 2D contour operations with tabs integrated. not working
Replies (10)
Message 2 of 11
seth.madore
The Trace toolpath doesn't actually produce arc movements, but very small point-to-point line moves. I don't think I've heard of UGS not supporting arc moves, but I suppose it's possible.
What post processor are you using?
Seth Madore
Message 3 of 11
I use the Grbl / grbl post processor
Message 4 of 11
These are the .nc files
Message 5 of 11
seth.madore
And all, or none of these above files will run on your machine?
Seth Madore
Message 6 of 11
the 9 rings file and the boogje contour file wont run correctly.
Both turn arcs into straight lines.
Message 7 of 11
seth.madore
Is it the display that's wrong, or does it actually cut wrong? What happens if you lift the tool well above the part and run it? Does the UGS need any updates?
Seth Madore
Message 8 of 11
Both in the display and the machine run wrong. Instead of arcs it makes straight lines.
Message 9 of 11
seth.madore
Is your UGS software up to date? This post processor has been out for quite some time, and I think this is the first report I've seen of it not working. Is there a UGS user forum where other users are saying the same thing?
Seth Madore
Message 10 of 11
seth.madore
We can eliminate all arc moves from your post processor if you want, it's a simple edit.
Open up your post processor in your favorite text editor. Change this line:
allowedCircularPlanes = undefined; // allow any circular motion
to this:
allowedCircularPlanes = 0; // allow any circular motion
Seth Madore
Message 11 of 11
Yes!!,
Someone from a UGS forum solved it. Apparently I needed to check a box in settings to enable arc movements. This solved my problem.
Thanks for the help!
My UGS is up to date as well. Heres a picture of the solution.
