Problem generating toolpath...please help
- Mute
- Permalink
- Report
I ve just finished my first design and G code preparation from fushion 360. Everything is really nice, but i have a strange problem after exporting gcode. I am using newest version of Mach3 as a controling program for my 3 axis CNC machine so i selected Mach3Mill.cps - Generic Mach3Mill as post processor. I am quite sure, that my setup and toolpaths are right, i followed a step by step tutorial, also the simulation looks like it should. Also my orientation and stock point is selected in a right way. But after exporting Gcode and importing it in Mach 3, there are some very strange paths inside the file which should not be there. The toolpaths as in simulation are there too, but there is a strange super deep path for Z axis, which goes as a first movement and also some strange X axis path going way far from the workpiece. Because of this i cant even start the job, because i am forced to emergency stop the process because of the strange Z axis movement in the beginning to prevent machine damage. Axis reference points in the mach 3 are set right. Toolpath screen is showing the original path with the strange ones, i f i use some onlin egcode viewer there are none of the strange paths.
Can anybody please help locate the problem? I am quite new to fushion 360 but this is very strange i think this can be caused during the export process, but i am not sure maybe I am just missing something.
Thank you very much for any suggestions i am attaching my Gcode and fushion screenshot for better example. Also i am attaching screenshot of the path from mach3 after import where you can see the strange paths (the red ones going deep) which should not be there please note that the view is rotated.
Ondrej CZ
