Good morning,
I'm having a problem with the piece comparison. Example:
I do a contour milling with a milling cutter and on the material screen to be left I already apply a correction on the side material of -0.05 mm and at the final moment of machining to the comparison instead of seeing the red face shows it to me with the original color of the face of the piece. the problem is that if the appearance of the blank is green you can make a mistake. the parameters of the comparison are: material to leave 0.00 mm, while the tolerance at 0.02 mm. it would be useful to also have the possibility to apply a "part violation" because when you remove more material than the solid you stop the simulation and error.
I hope I have been clear enough.
Best regards
