Probe WCS angle - weirdly shifts
- Mute
- Permalink
- Report
Hi guys,
I am playing with F360 WCS probing and tweaking PP. But when I reach the Angle WCS measurement I can not wrap a head around one movement F360 does. Maybe it is a bug, may be it is a feature. Either way, I would like to understand it.
I will try to describe it on situation, so you can replicate it.
Lets say, we have a block, with some angle feature on top, like one on this picture.
And you are trying to probe that angle on the feature. The probe itself have some Diameter, and probing strategy have Approach, Spacing and Overtravel options filled out. F360 will generate "toolpath" or attributes for the probe macro should I say, as it is more precise description.
For my understanding, for Renishaw macro, we need Overtravel, Angle (of the feature we are probing on), Spacing (between two probe points - parallel to axis) and X or Y position (of the feature surface in midpoint / starting position). This picture from Renishaw manula helps to clarify:
I added a question mark where the shift happens in fusion. The way, how PP for Fanuc calculate the Y attribute = Yorigin + Approach + 1/2*Probe Diameter. For simplification we can say Y coordinate is 0. It means, the "?" size is determine by those Approach and Probe Diameter attributes and thus is fixed.
But I noticed, that this "?" size is shifting if I change the angle of the feature.
When the angle is 80° it has smaller size than 45° which have smaller size than 10°. But Approach and Probe Diameter is the same.
Why is that happening?
My issue with that is, Fanuc PP doesn't compensate this movement at all. I think it is not crucial, as the importance is the angle, which we are measuring. But anyway, If I want to calculate how far should I probe in desired axis, I am calculating the distance by Y or X attribute compared to my starting position. And this distance will be wrong / shifted by this shift. This issue can be hidden in overtravel distance which is 10 mm by default, but if somebody put smaller overtravel, it can happen that probe doesn't reach the feature and rise an issue.
Or am I missing something?
