Pre drill position
Pre drill position
CnCTCA
Pre drill position
CnCTCA
Community Visitor
Community Visitor
Hi all,
In Fusion 360 CAM for machining slots, I pre drill first to avoid endmill plunging into material then slotting with endmill, but when I wanna select predrill tool entrance the software does not recognize pre drill entrance, and sometimes endmill start into material rather than existing predrill. Is there any solution?
crazybrain13
You have to manually select the predrill positions you want to use. It will NOT automatically detect where the predrill locations are.Slot Predrill Example.png
