PostProces CHANGE Cutting Feedrate WARNING
veso58S5W
Message 1 of 15
veso58S5W
WARNING   WARNING   WARNING
After latest update, PostProcess change Cutting Feedrate on it's own to the same as Ramp or Plunge Feedrate (default 333.333mm/min)
Who knows what else is wrong in Manufacture? Toolpath? Cuts? Speed?
Here is a photo of my Cutting Feedrate.
Attached is the NC Code file.
Open it to see line N95. F333.3 is totally wrong!!!!!!!!!!!!!!!!!!!!!!!
AutoDesk:
Immediately fix problems with Manufacture in Fusion360.
You might be liable for huge damages in material, injuries and human life.
Replies (14)
Message 2 of 15
HughesTooling
I'm not seeing the problem in my test file. Going to need more info. Can you share your design or mock something up to demonstrate the problem also what postprocessor are you using?
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 15
veso58S5W
1. I don't know what you mean saying - "test file"?
2. Design doesn't have nothing to do with CAM part of the program. It is a simple box what I want to cut with 2D Contour.
3. I use what Fusion supplied for Fadal CNC. Here is a photo attached.
You can see that it was updated on 3rd. EXACTLY after that update I got problems.
This is not the only one. Fusion behaves like retard now.
This is really horribly dangerous.
Post switch feed rates, thus run machine very slow in Cutting Feed.
Such things can have severe consequences.
Message 4 of 15
veso58S5W
I just played with 2D Contour settings, and tested toolpath editing box/F360 Postprocess.
What is happening is this:
Fusion Postproces takes Ramp Feedrate and throw it instead Cutting Feedrate (after G1..... command) what was set in editing box of the toolpath.
THAT IS HORRIBLE MISTAKE
Message 5 of 15
daniel_lyall
In the Gcode you supplied there is 6 333.3 moves and it is the plunge feed rate doing it,  you only plunge into an existing hole otherwise it can and will break a cutter a user risk.
All this is simple to test for set the plunge rate to a stupid amount.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 6 of 15
veso58S5W
Please DO NOT REPLY to messages without any meaning to the problem.
You didn't supply any solution.
Message 7 of 15
HughesTooling
By "test file" I mean I made a file to test because you can't be bothered to supply a design that shows the problem. So I made another test file that looks somewhat like yours and posted with the Fadel post and it works fine so unless you can be bothered to supply a file I doubt anyone can help.
Here a back plot, ramps are dark brown(500mm/min) and cutting feed rate are green(2500mm/min). Shows the feed is changing between all ramps and levels.
Mark
Mark Hughes
Message 8 of 15
HughesTooling
Ok just backplotted your file from the first post and don't see what's wrong.  Plunge is at 333, lead in 1000 then ramp 333 when it reaches depth feed changes to 2558, changes to 639.5 for corners does this every level?
Mark
Mark Hughes
Message 9 of 15
veso58S5W
Did you run this script on CNC? Probably didn't. Othervise you'll see that your Cutting FeedRate is 333.333.
I don't know your experience, I don't know who you are. But, what you made here shows that I am right.
F360 takes value of Plunge FeedRate and place it in/as Cutting FeedRate. Somebody made horrible mistake in that update.
If you have contact with them, PLEASE warn them.
I red on other forums people already crashed their machines.
Message 10 of 15
HughesTooling
No I didn't run it on the machine but the G code is correct if you can't see that you don't have much experience yourself. The code you posted shows the ramps are cut at 333 and all toolpaths at each level are cut at 2588. You can see in your code the first 333.33 feed is on the plunge then it changes to 1000.00 for the in feed then back to 333.33 for the ramp, the next 6 lines are all ramp moves with the Z moving then when it reaches 10mm depth it changes to 2558mm this is all correct, if your machine is doing something different it's not down to Fusion or the G code.
If your machine is doing something different it's a problem with the machine not the G code. Perhaps you should contact the machine supplier.
Mark
Mark Hughes
Message 11 of 15
HughesTooling
As you asked about my experience, I started using computers in 1982, started with CAD in 1992 and CNC in 1996. I use Fusion every day to program 6 mills with 4 different controls, 2 lathes and 2 4 axis wire eroders so yes I can read G code and no what I've posted and what you've posted shows there's no problem with the code. If your machine is not doing what the code requests the problem's with your machine.
This is from your file. This is all correct and giving the feed rates you've set.
N60 G43 Z40. H2
N65 Z15.
N70 G1 Z11. F333.3                      <--------------------Plunge feed rate
N75 Z2.973
N80 G19 G2 Y166.811 Z0.5 J-2.473
N85 G1 Y164.338 F1000.                  <--------------------Lead in feed rate
N90 G17 G3 X433. Y161.865 I2.473
N95 G1 X874.865 Z-0.962 F333.3          <--------------------Ramp feed rate
N100 Y-11.865 Z-1.538                   <--------------------Ramp feed rate
N105 X-8.865 Z-4.462                    <--------------------Ramp feed rate
N110 Y161.865 Z-5.038                   <--------------------Ramp feed rate
N115 X874.865 Z-7.962                   <--------------------Ramp feed rate
N120 Y-11.865 Z-8.538                   <--------------------Ramp feed rate
N125 X433. Z-10.                        <--------------------Ramp feed rate. First level reached
N130 X3.5 F2558.                        <--------------------Cut feed rate
N135 X-3.919
N140 X-8.865 F639.5                     <--------------------Feed optimisation feed rate
N145 Y156.919 F2558.                    <--------------------Cut feed rate
N150 Y161.865 F639.5
N155 X869.919 F2558.
N160 X874.865 F639.5
N165 Y0.5 F2558.
N170 Y-6.919
N175 Y-11.865 F639.5
N180 X433. F2558.
N185 X-8.865 Z-11.462 F333.3            <--------------------Ramp feed rate. Next level back to ramp feed
Mark
Mark Hughes
Message 12 of 15
seth.madore
Sheesh! I take my daughters camping and the whole place falls apart!
@veso58S5W  I am not seeing this issue in my posted code. Please attach the Fusion file that you use to produce this error. Yes, it matters, as it contains all your CAM settings, and that is what will lead us to the most correct answer.
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Message 13 of 15
HughesTooling
@seth.madore  Initially I didn't read the first post carefully as I wanted to see the f3d first. Now I see the OP says line 95 changes to a feed rate of 333.33 and it's the wrong feed rate. Trouble is the screengrab shows the ramp feed rate at 333.333 and line 95 is the first line of the ramp so it's correct. So no real need to see the file as the code is posting correctly.
Mark
Mark Hughes
Message 14 of 15
adamNT4S4
At least, the your post processor isn't taking your feed rates and dividing it by 47.904 for all of your feeds. This is what I have set for my feed rates in fusion. Looks like someone pissed off your computer programmer before this last update. I had to manually change the feed rates in the gcode. It was melting the $375 sheet of HDPE that I was cutting destroying the sheet.
Message 15 of 15
programming2C78B
this thread is over 4 years old.
My guess is you have something going on inside your Post (which you included no information about).
Please click "Accept Solution" if what I wrote solved your issue!
