Posting multiple operations (same tool) to one subprogram
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm currently programming some parts on a horizontal, I want to be able to post multiple operations (same tool) to a single subprogram not by individual operations... is this possible? I currently have these grouped in individual folders separated by what work offset they are attached to as I need to use several different WCS's. For example, I have a 3/8" endmill running 4 different toolpaths on my G54 work offset with the tombstone rotated at 0 degrees and then I'm running another 3 toolpaths with the same tool using G55 with it rotated at 90 degrees. Was originally hoping that if I checked off the "pattern" tab in my folder and just made a duplicate at the same location and unchecked the "keep original" tab that this would be recognized when posting with sub programs and choosing
'patterns" but no such luck. This will post all my sub programs and all my WCS/rotations correctly using "operations" but trying to avoid having to manage 97 different subprograms, if I could do this it would be reduced to about 15 which is much more manageable.
