Posting does not have A axis. Need generic Gcode posting for this
cgchrist
Message 1 of 9
cgchrist
I have a custom CNC mill with a rotary that we need to post to.   It runs a LinuxCNC controller that obeys RS274 spec g code.   We have a rotary on this mill and the rotary is the A axis.   I get the following screen shot errors.   Any help would be appreciated.
Replies (8)
Message 2 of 9
seth.madore
Are you using a Machine Configuration that has an -A- Axis defined? The EMC2 will give you -A- axis code if you use a machine config:
Seth Madore
Message 3 of 9
cgchrist
I've tried to change that and I get the following errors on saving.   I've tried a few times with the same results.   Any suggestions on this?
Message 4 of 9
seth.madore
You need to save your file before you can add a machine to the Setup
Seth Madore
Message 5 of 9
cgchrist
Thanks for working with me on this.   I closed out and saved the file.   When I went to post again I had the same issue.    I think the log is the same as before but this is the current screen shot...
Message 6 of 9
jliraK7TPC
If you try unchecking this box?
the same error happened to me, because I used a post initially configured for 3 axes with option to configure a rotary axis (A), then the post has a machine configuration and when writing the NC it conflicts with the machine configuration of that box.
Message 7 of 9
cgchrist
Hi.
Thank you I did try that but ran into the same issues.   Maybe I am not configured correctly?   If I am not, i'm not sure how to.   Any help with this would be appreciated.
Message 8 of 9
cgchrist
I did try the EMC2 with the same results as well.
Message 9 of 9
cgchrist
I am able to get portions to post.   I have a bore operation and it will post that.   I went through the list of operations and toggled one on at a time and could get the bore options to run.   I couldn't get the drill or thread operations to post.    I'm pretty green to fusion but I feel that if I can toggle on/off what is stumbling me, I should be good to go.   Thanks,
