If your issue indeed is that you are cutting on/below the X centerline, you need to change a value in the post to allow for that. I've screenshotted the place you need to be. See the line numbers on the left and the description of your machine model on the top line. This is where you would need to change the 0 to how far your tool can go below centerline. (Usually, this is tricky as it's further on one end of the Y-axis stroke than on the other end, hence generally 0 is used.)
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
