POST RE-ORDER TOOL CHANGE
Chris.Vollmer
Message 1 of 9
Chris.Vollmer
So i dont know what happend but i just updated a few tool paths and reposted. this is the first post since the new update and my tool changes are now not in the order they need to be in with 2 programs running together. im not sure what happend. but i cant get it to change.
Replies (8)
Message 2 of 9
oscar-cadcampilot
You might have the "reorder to minimize tool changes" option checked in the post dialog.
Oscar Romero
Owner | Product Specialist
@ cadcampilot
Message 3 of 9
Chris.Vollmer
I want that checked. i have my program running op1 and op2. they are in different programs but run off the same work offset. i have always checked that box and it worked but now it does all of op1 then all of op2. completely defeats the purpose.
Message 4 of 9
oscar-cadcampilot
There's seems to have been some changes to the way NC programs handles some items. This might be affected as well.
Not sure which post you're using but I just tested on my side with the generic Haas 3 axis post. You should have a separate Setup and offset for each of your ops. That should do it.
You can just make a copy of the setup, number it separately and add or remove any tools for the individual ops.
Oscar Romero
@ cadcampilot
Message 5 of 9
Chris.Vollmer
Im using the same post i always have. im not sure whats going on. i switched back to the legacy post and still having the issue. its pretty frustrating. i just tried using 2 work offsets but still didnt work. I do have Patterns in the operations. but i had them before so im at a loss here.
Message 6 of 9
oscar-cadcampilot
Can you share your file and post here?
Oscar Romero
@ cadcampilot
Message 7 of 9
Chris.Vollmer
its a big file.
This is the order i am wanting and i have had in the past
T1 -- op1
T2 -- OP1
T4 -- OP2
T10 -- OP1, OP2
T3 -- OP1
T5 -- OP1,02
T6 -- OP1
T7 -- OP1
T8 -- OP1,0P2
T9 -- OP1
T3 -- OP1
Message 8 of 9
oscar-cadcampilot
Something is off here, unless I'm understanding.
Going by your tool and op list above, it seem that some of the toolpaths in your project don't have the right tools assign to them. This is before even going to post.
Have a look at each toolpath in your project and make sure that the right tools are assign to each of them.
Oscar Romero
@ cadcampilot
Message 9 of 9
Chris.Vollmer
its correct, im currently running the program now its just doing more tool changes than necessary. That list is what i want it to be. And something i had previous.
