Post programe
Post programe
Message 1 of 23
Post programe
Curently using Enroute for machine gcode and tooling is there an easy way to find the correct post code from fusion to my machine without just trying all the types?
Replies (22)
Message 21 of 23
scottmoyse
@Anonymous wrote:
Hi again VERY excited I found a generic fusion post the runs my machine and cut some 3d contoured faces into foam yesterday it was the opticut.cps generic.
This has no tool changeing but the code outputs to the machine!!!
I ran your post process and the I  and  J values have to be whole numbers for it to work but ther is still a G0 Z0 move that would crash the machine at start and finish I will attach the txt files.
I also ran a Generic NUM test it had sucsess in the machine but had a G0 Z0 at the start and finish of the cycle.
Multicam Australia run a different A2CM controller software from what I have found out and are not much help when it comes to questions about other programes they do not sell.?
Thank you again for the help looking at this problem and I know a few people that run these machines in Australia that would be very interested in a post programe that functions with Fusion!
@Anonymous can you direct message me your phone number please? I'm currently working on a generic post with Multicam Australia and would like to pick your brains. I work for the ANZ autodesk cam distributor, cadpro.co.nz. We're the technical resource for the region. my email is scott dot m at cadpro.co.nz if you would rather email.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 22 of 23
Please email me direct and i should be able to help leoncarter83@bigpond.com
Sent from my Samsung GALAXY S5 Mini on the Telstra Mobile network
Message 23 of 23
post cps
