- Mute
- Permalink
- Report
Heya,
Really struggling with post processing here. I've been working solely in G53/54 for all the CAM work I've done so far but thought I'd introduce multiple WCSs after watching this video from NY CNC showed me how easy it is to set up: https://www.youtube.com/watch?v=-Qtvj5iM_VI
How wrong I was.
I've checked 'Multiple WCS offsets' and set the duplicates to 2 or more but when I post-process the code is no different to that which is processed without it checked. I have a feeling there is something I need to change in my post processor. Would that be right? It's not something I feel confident messing about without a bit of guidance.
Has anyone had a similar issue when using this feature?
For info: I'm running Fusion 360 to drive a Mach3 machine and I'm currently using the Generic Posts Mach3Mill as my post processor with no changes made to it. To try and locate the issue I have tried using alternative post processors but these also compile without repeat operations on additional WCSs.
Thanks in advance for any help out there.
Chris
p.s. Some photos attached if of any use.
