Post Processor Precision (decimal places)
russtuff
russtuff
I am running into an error using LinuxCNC (see below), and it appears this may be due to Fusion only outputting 3 decimal precision. I have found in the LinuxCNC documentation that when working in inches, four decimal precision should be used. Any way to change this within Fusion? Or maybe there is some other obvious solution to this error?
I am not able to machine a part I need, due to this error. Check the spoiler below the error message to see the gcode. Line N90 is the troublemaker.
ERROR: Radius to end of arc differs from radius to start
Spoiler
(T2 D=0.25 CR=0. - ZMIN=-0.75 - FLAT END MILL)
N10 G90 G94 G17 G91.1
N15 G20
N20 G0 Z3
N25 M9
N30 T2 M6
N35 T3
N40 S4600 M3
N45 G54
N50 M8
N60 G0 X-0.868 Y2.675
N65 G43 Z3. H2
N70 G0 Z0.2894
N75 G1 Z-0.225 F3
N80 G18 G2 X-0.843 Z-0.25 I0.025 K0.
N85 G1 X-0.818 F10.
N90 G17 G3 X-0.793 Y2.7 I0. J0.025
N95 X-3.003 I-1.105 J0.
N100 X-1.7733 Y1.6021 I1.105 J0.
N105 X-0.8212 Y2.9479 I-0.1247 J1.0979
N110 X-0.8511 Y2.9666 I-0.0244 J-0.0056
N115 G1 X-0.8755 Y2.961
rus, making stuff
youtube.com/russtuff
HughesTooling
It looks like lines 100 to 110 are giving you 4 decimal places, the only reason you have less on other line is because trailing zeros have been removed. The code back plots ok so I don't know why you are getting an error, are the any settings for arc correction in LinuxCNC.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff.walters
I have a couple of questions from what I'm seeing. Does your machine support arcs not in the XY plane? If not try putting a 0 in your vertical lead-in radius. That will get rid of the G18 line.
The second is does your control setup need the G2 or G3 on every arc move? If it does it’s a simple post fix to correct it.
Jeff Walters
Senior Support Engineer, CAM
russtuff
Good catch. I posted this late and completely missed the four decimals elsewhere. I use Gwizard Editor for backplot and it works perfectly there too,
rus, making stuff
russtuff
I belive it does support arcs in the outside of the XY plane, as I have used F360 many times for similar operations.
I'm not sure about needing G2 or G3 on each arc, and I will test that tonight and report back. Thanks!
rus, making stuff
russtuff
Well I wasted a ton of time trying to fix this and never did. I shut down linuxCNC as a guess and sure enough, the next time I loaded the program I received no errors.
Thanks for taking a look guys.
rus, making stuff
