Post processor outputting wrong dimensions (Haas)
jsilverio86
jsilverio86
So my post processor for my Haas lathe is giving me wrong diameters at the post or software level. I made a simple test and my model is 2" to a 1" step and fusion simulation and PP are spitting out 1.9861 and .9861
Is there a setting that I am unaware I am using?
Here is my code for the finishing pass. I've also included my model with simple tool paths and a pic of simulation where I assume it in radius mode but still off.
(Profile Finishing1)
G99
G18
G0 Z0.1961
X3.0361 Y0.
G50 S4000
G96
S1200 M3
Z-0.0088
X1.1461
G1 X0.9861 F0.008
Z-1.0008
X1.9701
G3 X1.9861 Z-1.0088 I0. K-0.008
G1 Z-2.0088
X2.1461
G0 X3.0361
Z0.1961
G97
S1510 M3
M9
G53 Y0.
G53 X0.
G53 Z0.
M5
M155
G53 G0 Y0.
M30
seth.madore
That is because you have your Compensation point (in the Tool Library) set to "Tip", when it should be set to "Tip Tangent"
Results when changing it to that method:
N16 T404
N17 G99
N18 M22
N19 G97 S1503 M3
N20 G54
N21 M8
N22 G0 X3.05 Z0.1969
N23 G50 S5000
N24 G96 S1200 M3
N25 G0 Z-0.008
N26 X1.16
N27 G1 X1. F0.008
N28 Z-1.
N29 X1.984
N30 G18 G3 X2. Z-1.008 K-0.008
N31 G1 Z-2.008
N32 X2.16
N33 G0 X3.05
N34 Z0.1969
N35 G97 S1503 M3
Seth Madore
jsilverio86
Thank you for the response. I guess I do not understand the relationship between tip or tip tangent and how it affects offset. I though tip was the most outer part of the tool.
seth.madore
The best visual representation you can get (in Fusion) is to set it to "No Holder", see attached photos
Seth Madore
