Post Processor - Makino PS
Message 1 of 16
Is there any post processor available for a Makino PS 3-axis vertical milling machine?  It has a Fanuc controller.  I have tried the Fanuc Generic post processor but it seems to be missing a few G and M code line in the initialization.
Replies (15)
Message 2 of 16
LibertyMachine
My advice? Post out with the generic Fanuc post, manually add those codes in, run it at the machine and see if it needs anything else. Compare the generic output code to proven code you've run and mark up the differences.
The Generic posts are usually all that is needed for "most" machines, and they also provide excellent starting points to build up for your specific machine.
Adding in various M and G codes usually isn't too big of an issue and something we should be able to help you with
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 16
Thank you! I will carefully dissect both files and get back to you.
Travis
Message 4 of 16
Here are the headings from both posted files.  I highlighted the differences in RED.  The like commands are in BOLD.  The one thing that I notice is the M23 command in the Makino post.  Do you recommend any changes to the Fusion post?
Message 5 of 16
LibertyMachine
And there was NOTHING else anywhere? At M01's, at the end of the file, everything else was fine?
Seth Madore
Message 6 of 16
LibertyMachine
Couple further questions;
G21 is the Fanuc call for working with metric values. If you work in imperial and move over to metric the control won't know the difference. The revers applies as well.
So we have:
G0 and M23 added to the safe start block
and G0, 01, 02, 03 reduced to one digit: G1, G0, G2, G3
Anything else?
Seth Madore
Message 7 of 16
After that it was just all of the tool path coordinates.
Message 8 of 16
LibertyMachine
Give this post a shot. I've left in the G20/21 call. If you really want it out, I could do that I suppose. I'm not a fan of removing safeties unless there is a clear need.
DO NOT, I repeat, DO NOT store the post where the generics are stored. They will get wiped out at the next update. Personally, I leave them local while I am tweaking the post. You can direct the Post Process browser to where they are stored. Once I have them how I want, I put them on the cloud.
Seth Madore
Message 9 of 16
Thanks. I'll take another look at the end of the programs tonight to see
if any differences stand out.
Message 10 of 16
LibertyMachine
The changes may be at the end of every tool and most likely at the end of the file.
Seth Madore
Message 11 of 16
I noticed that the end of the file is slightly different.  Both do a move to home position.  Looks like Makino stops the spindle before ending the program.  Also different time when the coolant is turned off.
Makino posts the following:
G91G28Z0.
G91G28Y0.
G49
M09
M05
M30
While the Fanuc Generic posts:
M09
G28 G91 Z0.
G49
G28 X0. Y0.
M30
Message 12 of 16
LibertyMachine
I've made the edits you wanted. However, I do want to point out that what you've asked for is largely irrelevant to the successful operation of running the machine. Where an M9 or M5 is on the line of code won't really impact you one way or another. I realize that seasoned machinists prefer code to be laid out a certain way, as I am the same way. I can't even begin to list how far my own Fanuc post has strayed from the generic output...
Seth Madore
Message 13 of 16
Steinwerks
To be fair, if the M5 comes before the M9 on our Haas the coolant doesn't turn off until the spindle has stopped, leaving the tool drenched when it goes back in the ATC, so there can be practical reasons.
The Fadal is different, it'll turn off both in the same line and the spindle stops while it's retracting to home zero even though that's not on the same line (I wish the Haas would do that).
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 14 of 16
LibertyMachine
I....did not know that, thank you for chiming in @Steinwerks!
Seth Madore
Message 15 of 16
Thanks for your help. I will test it out on the machine tomorrrow.
Message 16 of 16
I have a makino  v55 and I cant seem to get post to work at all.
here is mastercam that works.
mastercam
G20
G0G17G94G40G49G80G90M5
T24
M6
G0 G90 G54X0.Y0.
G0X1.08073Y-8.24686
M56 H1 D2
S3500M3
G43H1Z8.
Z4.72
G5P10000
G1Z4.44F30.
X.7886Y-7.95473
G2X.74833Y-7.8575I.09723J.09722
G1Y-7.07136
G3X.57086Y-6.8939I-.17746J0.
G1X-.57087
G3X-.74833Y-7.07136I0.J-.17746
G1Y-7.8575
G2X-.7886Y-7.95472I-.1375J0.
G1X-1.08073Y-8.24686
Z4.64F350.
G5P0
G0Z8.
here is fusion generic post that wont work. wont even tool change.
fusion
O1001 (TEST)
(T2 D=1. CR=0.015 - ZMIN=-1.2282 - BULLNOSE END MILL)
N10 G90 G94 G17 G49 G40 G80
N15 G20
N20 G28 G91 Z0.
N25 G90
(ROUGH OUTSIDE)
N30 T2 M06
N35 S2200 M03
N40 G54
N45 M08
N55 G00 X-0.5936 Y-1.2349
N60 G43 Z0.4 H02
N65 G00 Z0.0594
N70 G01 Z0.021 F30.
N75 X-1.1722 Z0.0201 F90.
N80 X-1.2161 Y-1.2367
N85 X-1.2587 Y-1.2391 Z0.02
N90 X-1.3004 Y-1.2436 Z0.0199
N95 X-1.5503 Y-1.2763 Z0.0196
N100 X-1.649 Y-1.2918 Z0.0194
N105 X-1.8534 Y-1.3246 Z0.0191
N110 G02 X-1.8685 Y-1.3266 I-0.0411 J0.2567
