Post processor list scrolls out of control
Message 1 of 10
Running on a mac and when I go to change generic processors the cursor will not stop and sit on a selected processor. It just blows past or above. Tried holding various keys down while scrolling but no luck.
Anyone see this? I have only seen it now that I started using a mill and lathe post. before I never changed from the mill.
Thanks!
Ian
Replies (9)
Message 2 of 10
Tried track pad and 2 different mice.
no change
Message 3 of 10
Steinwerks
I don't have a Mac, and have never experienced this issue nor heard of it, so the best thing to do in my estimation would be to make a Screencast and attach it here. Generally when I have had unstoppable scrolling or repeating behavior issues it's because a key got stuck and I didn't notice it (and yes, I feel dumb when that happens and I think my computer hates me, then I realize I missed the clues).
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 10
Screencast attached.
Hard to tell, but I cant select what I want. no matter how slow or steady I hold the mouse / track pad.
Message 5 of 10
macmanpb
I have looked into that issue and have the same behave.
The user is not able to select lower items in the list.
My Mac specs.
Message 6 of 10
jeff.pek
HI all -
This is a Mac-only issue that was discovered early this month.
A fix has been made, and will be delivered as part of the January update in a few weeks.
Sorry for the inconvenience.
Jeff
Message 7 of 10
LibertyMachine
That's good that a fix is incoming, but if I understand this right, how is someone able to select something on the list while it is scrolling?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 8 of 10
jeff.pek
Selection works OK at the top of the list, so I think the only thing you can do is to use a post that's up high in the list, or have a smaller list.
If you copy the post(s) you need into your own folder, and then work from that folder, I would think you can work around this behavior.
Jeff
Message 9 of 10
Glad a fix is inbound. New Lathe gets delivered 0n the 30th and I will be flipping between posts often.
As far as dealing with it now you "can" select lower items. Its just like a carnival game... Took me 20 min to get the one I wanted last night!
Thanks again!
Ian
Message 10 of 10
paul.clauss
Another workaround for this issue that I like to use is to create a small cloud library with just the posts you consistently use. Also, using the mouse wheel to scroll (instead of the top/bottom of the list) might help make things a little more manageable!
Paul Clauss
Product Support Specialist
