post processor for sinumerik 802s
Message 1 of 17
 Hello, I needed a post processor for Sinumerik 802S. I read the forum, but nothing helped me. The system will not accept my data, always displaying "DATA ERROR".
Replies (16)
Message 2 of 17
LibertyMachine
Are you getting these errors with the 802D post processor that is shipped with Fusion?
If you could tell us the difference between the "D" and the "S" control types, we might be able to get you a quick edit to sort you out.
Does deleting or adding a certain line or block make everything better?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 17
Yes, I used the postprocessor for Sinumerik 802D
Message 4 of 17
LibertyMachine
Ok, and on what line did it generate an error? Have you done any trouble shooting on your end to determine what the controller WANTS to see versus what it's getting?
Seth Madore
Message 5 of 17
I tried to modify the code according to advice on the forum, but nothing helped me. On which line the error occurs I do not know, sinumerik will not even accept it, so I can not see it. after transmitting the program, you will see data error and that's all.
Message 6 of 17
LibertyMachine
Well, do you have any other program that has been generated with other software or that came with the machine?
Seth Madore
Message 7 of 17
Yes, there is one program in the memory of the machine that was left behind by the previous owner. I do not use any software other than fusion 360 to generate programs.
Message 8 of 17
LibertyMachine
It would seem to me that the next step would be to open up that old program in Notepad or Brackets and do a side by side comparison of the opening and closing lines, see where they diverge. Once you can narrow down what they might be, start modifying the Fusion posted code to be the same and see what does the trick. It's not a quick procedure, but it's also not something we can help you with, unless another user has an 802s control (which I don't think we have anyone that has that style)
Things to look for:
Special characters at any point the program that are not in the other
M or G codes that are not present in the other
Formatting of the program number, presence or abscence or a "O", ":", "%" etc
Do you have the manual for the machine? What does "Data Error" suggest for solutions?
Seth Madore
Message 9 of 17
I found the manual.
Data errors
1. Files read in with / without leader
or
2. Files transferred in tape format without file name
so I try to modify the program. Do you know any software that could convert code from 802D to 802S? Or if it was not too demanding, would it be possible to modify the 802D post processor?
thank you for your quick support
Message 10 of 17
LibertyMachine
Before we edit the post processor, you are going to need to narrow it down further. What is the "leader" that is or is not present?
Sorry, I do not know of any software to convert one file into the other. Siemens is not something I've ever used..
Seth Madore
Message 11 of 17
Ok, when I correct the code I'll let you know.
Message 12 of 17
I fixed this short program to work. I send the same program twice, the "fixed for 802S" file works. The "802D post-processor" is generated for the 802D version. All changes are at the beginning and the end. Lines can not be numbered.
I can not send the program as a file, so I send it like this. the arrow at the end is in the program as "SUB" in black background.
802D post processor
; %_N_NAST-RAM_802D_MPF
N10 ; T1  D=6 CR=0 - ZMIN=-8.5 - flat end mill
N11 G90 G94
N12 G71
N13 G64
N14 G17
N15 G53 G0 Z0
N16 ; Slot1
N17 T1 D1
N18 M6
N19 S3448 M3
N20 G54
N21 M8
N22 X49 Y-22
N23 Z15
N24 Z0
N25 G1 Z-2.5 F100
N26 Z-5.5
N27 X10 F350
N28 Z-8.5 F100
N29 X49 F350
N30 G0 Z5
N31 Y-8
N32 Z0
N33 G1 Z-2.5 F100
N34 Z-5.5
N35 X10 F350
N36 Z-8.5 F100
N37 X49 F350
N38 G0 Z15
N39 G17
N40 G53 G0 Z0
fixed for 802S
%_N_NAST_ram_2_MPF
;$PATH=/_N_MPF_DIR
G90 G94
G71
G64
G17
G53 G0 Z0
; Slot1
T1 D1
M6
S3448 M3
G54
M8
X49 Y-22
Z15
Z0
G1 Z-2.5 F100
Z-5.5
X10 F350
Z-8.5 F100
X49 F350
G0 Z5
Y-8
Z0
G1 Z-2.5 F100
Z-5.5
X10 F350
Z-8.5 F100
X49 F350
G0 Z15
G17
G53 G0 Z0
M30
Message 13 of 17
LibertyMachine
Do you know if this line is needed:
;$PATH=/_N_MPF_DIR
or is this ok:
; TEST FILE FOR 802S
This would be the program comment in the setup
Seth Madore
Message 14 of 17
I tested it and $ PATH = / _ N_MPF_DIR did not need to be there.
Lines can be numbered.
the "SUB" tag must also not necessarily be there, it only terminates the transfer from PC to machine, without it being necessary to terminate the transmission manually.
Only the first line is generated commented (;% _N_NAST-RAM_802D_MPF)
just delete comment (% _N_NAST-RAM_802D_MPF)
I tested it on multiple programs and it works.
I tried to send the program about 2500 rows but the transmission did not even start. I pretend that for this I will have to adjust the transfer settings.
I do not think postprocessor will need to be edited to delete the comment. Thank you so much for your support.
%_N_802S_TEST2_MPFN
N10 ; TEST FILE FOR 802S N11 ; T1 D=6 CR=0 - ZMIN=-8.5 - flat end mill N12 G90 G94 N13 G71 N14 G64 N15 G17 N16 G53 G0 Z0 N17 ; Slot1 N18 T1 D1 N19 M6 N20 S3448 M3 N21 G54 N22 M8 N23 X49 Y-22 N24 Z15 N25 Z0 N26 G1 Z-2.5 F100 N27 Z-5.5 N28 X10 F350 N29 Z-8.5 F100 N30 X49 F350 N31 G0 Z5 N32 Y-8 N33 Z0 N34 G1 Z-2.5 F100 N35 Z-5.5 N36 X10 F350 N37 Z-8.5 F100 N38 X49 F350 N39 G0 Z15 N40 G17 N41 G53 G0 Z0 N42 M30
Message 15 of 17
LibertyMachine
Let's give this post a try. I'd changed the first start line and turned off the line numbering.
Seth Madore
Message 16 of 17
It works. Thank you for your help.
Message 17 of 17
hello every body, thanks for giving the psto processor , but i have one more question. how to intall that postprocessor in my program? i just drag it to my post processors folder? thanks in advance for your help.
