Post processor for FangLing F2100B
Message 1 of 14
I've bought a CNC plasma machine that uses a FangLing F2100B. I'm currently using FastCam to convert the DXF files to NC/TXT files. I'm looking for a postprocessor for Fusion360.
Is there a standard postprocessor  available??
Replies (13)
Message 2 of 14
Marco.Takx
Hi @Anonymous,
Go to this website and search for DXF
https://cam.autodesk.com/hsmposts?
Give it a try.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 14
it realy works for FangLing F2100B?
Message 4 of 14
govinda_webster
Community Visitor
Community Visitor
Can you give some more infomation on these processors please? I would really like to forgo FastCam and use Fusion 360 to export straight to our machine. . .
Any and all help apprieciated. . .
Message 5 of 14
Did you solve this?
How do you currently convert from fusion360 to the fangling F2100B?
Message 6 of 14
timjames02
Community Visitor
Community Visitor
Did you find a post processor that works for the fangling controller??
Message 7 of 14
We are still using FastCAM because non off the postprocessors in Fusion360 works for the FangLing CNC.
We have tried various processors, but there's always something that doesn't work properly.
Message 8 of 14
jamesnjhelms
Old topic but it might help someone.
This controller will only read .CNC .NC or .TXT
Use Hypertherm jet in post and set pierce time to 0. Use the pierce time set in your controller.
This controller can read G4 F1 (dwell for 1 second) and set the feed rate to 1mm/m.
Use the default "in computer" kerf compensation within fusion and you're good to go.
If you want to use "in control" kerf compensation then you will need to edit your output code so the G41 command is a line above the M7 (torch on) otherwise it will pierce and pause or do a double pierce.
If you want to use the controllers speed settings on the fly then you can delete the F command from your program. The F will override anything you have set in the controller.
None of this following stuff is necessary but it helps to keep things simple.
In post preferences you can turn off "use sequence numbers" "write machine" and "allow head switches"
If you want you can delete the M19 and M30 at the end of your program, though the machine will ignore them anyway. The correct command to end program for this controller is M02 or M2 though it will just end with no problem if there is no more code to read.
Message 9 of 14
mspecdesign
thanks, ill give this a go today!
update: confirmed this worked fine, thanks jamesnjhelms
side note: The usb stick must be formatted to fat32 for the F2100b to read it.....had me frustrated for a bit that one haha.
Message 10 of 14
jamesnjhelms
Happy to help, thanks for the feedback.
Yeah the USB drive must be fat32 and there is also a capacity limit (16GB or 32GB?)
I have at least one fat32 USB drive that the machine refuses.
It's not a bad controller, in fact I really like it. I have ours setup with plasma and an LPG torch and it's done a ton of work, including full 2.4m x 1.2m nests, thousands of lines of code. Once you have your kerf dialed in it's as accurate as any, so long as your stepper motor pulses are dialed in (to do this, sharpen a tungsten or a piece of wire or similar and tape it to the torch holder, then run a tape measure down the X and Y and use the step function "step move" set to something big, like 2400mm or what have you. Adjust motor pulse until it's perfect)
I have since edited hypertherm's post processor to further suit this controller. Output code looks like a native "shape library" program and requires 0 editing, but it only works with the default "in computer" kerf settings in fusion.
I have a separate file for "in control" kerf settings if you're hell bent on setting kerf values from the controller (ask if needed)
Message 11 of 14
baabafadil
Thanks for the Tips though request you do like a video tutorial & post on YouTube & give us link here thanks
Message 12 of 14
ajmetalwork
Community Visitor
Community Visitor
Hi James,
Just wanted to say thank you for posting this!!
You have saved me hours of time trying to set this up
THANK YOU!!
Message 13 of 14
mdominguezNEMWY
Tnx for the cps, it works wonderfully!!!
Message 14 of 14
egodoySKYMH
Community Visitor
Community Visitor
yo estoy usando el postprocesador avic cnc de fusion que es el unico compatible con el controlador F2100B de maquinas genericas chinas.
Translation:
I am using the Avic CNC postprocessor from Fusion, which is the only one compatible with the F2100B controller of generic Chinese machines.
@egodoySKYMH - moderator has edited this post to provide for translation. Please use a translator to post in English.
