Post processor coolant mFormat
aloKVDTB
Message 1 of 9
aloKVDTB
Is there a reliable way to use special commands instead of plain M[number] to trigger air through tool?
The generic Hurco post does not allow anything but numbers in var coolants
{id: COOLANT_AIR_THROUGH_TOOL, on: 11Q1, off: 11Q0},
Thanks!
Replies (8)
Message 2 of 9
jlauschQGBNG
Look at what I did here and see if that gives you what you are looking for. In short instead of
{id: COOLANT_AIR_THROUGH_TOOL, on11Q1off11Q0},
I did
{id:COOLANT_AIR_THROUGH_TOOL, on: "M11Q1" , off: "M11 Q0"},
Message 3 of 9
aloKVDTB
Thanks, that did not work for me sadly
Stack dump:
("Invalid argument type.")@:0
getCoolantCodes(5)@C:/Users/ALvil/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/hurco.cps:2390
setCoolant(5)@C:/Users/ALvil/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/hurco.cps:2321
onSection()@C:/Users/ALvil/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/hurco.cps:1197
Failed while processing onSection() for record 487.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, December 30, 2021 8:35:24 AM
Post processing failed.
Message 4 of 9
jlauschQGBNG
I'm no expert with the post modification side of things however I have been able to make some changes to our posts at the shop. Drop you post file and I will see what I can do next week. It will be a .cps file like what I sent in the last reply.
Message 5 of 9
engineguy
@aloKVDTB
What does your HURCO Control accept for Coolant Commands ???
You need to check your HURCO Manual or contact HURCO for what codes are accepted by your control for the different methods of coolant use before trying to change the Fusion Post Processor, without that information everyone will just be going round in the "guessing circles" and getting nowhere fast 🙂
The Fusion Post Processor will most likely be able to be modified to output something different but without knowing what can/can not be used by your control then it is pretty hard to guess 🙂 🙂
Message 6 of 9
aloKVDTB
Got it
// M11Q1 + M11Q0 solved 30dec2021
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        if ((tool.coolant == COOLANT_AIR_THROUGH_TOOL) && (coolant != COOLANT_OFF)) {
          writeBlock(coolantCodes[c], "Q1");
        if ((tool.coolant == COOLANT_AIR_THROUGH_TOOL) && (coolant == COOLANT_OFF)) {
          writeBlock(coolantCodes[c], "Q0");
        } else {
          if (tool.coolant != COOLANT_AIR_THROUGH_TOOL) {
            writeBlock(coolantCodes[c]);
        //writeBlock(coolantCodes[c]); /*--originally just this in for (var c in coolantCodes) {}*/
    return undefined;
  return coolantCodes;
My postprocessor has a number of other modifications like G28 home even if safe retracts has been set to [Clearance Height] and there's delayed M63 aux2 off onClose so **caution**
Message 7 of 9
aloKVDTB
The problem was not with Hurco, air through tool worked if I manually wrote in code
M11Q1 //on
M11Q0 //off
I just needed the postprocessor to write the extra Q-codes with M11 when {id: COOLANT_AIR_THROUGH_TOOL, on: 11, off: 11was used in program
Message 8 of 9
Tomek.G
Hi @aloKVDTB,
I am wondering which version of the post you are using.
There was an update some time ago that allowed you to add a text string as a coolant code.
Tomek.G
Sr. Technical Consultant
Message 9 of 9
jlauschQGBNG
I was wondering why my fix worked for me and not for him. This would explain why.
