Post processing within Fusion 360
GeorgeRoberts
Autodesk Autodesk
Message 1 of 154
GeorgeRoberts
Good afternoon community!
The post-processing option has now been merged into the NC program experience.
The experience and functionality you get for post-processing used to depend on both what operating system you were using and what button you used to start post-processing. Over the past few months, we have been working on unifying these experiences by expanding NC programs to ensure it has all the functionality needed to replace the multiple post-processing dialogs that exist today.
One of the important changes to be aware of is the usage of the post library for post-processor management and selection. This gives you more ways to manage your post-processors and will give a better way of consuming post-processor updates from our Fusion 360 post library.
If you would like to continue to use your local drive to store post processors, simply 'link' your local drive to the post library by right-clicking on the 'linked' option and choosing 'link folder'
Like always with post-processing, check your selected post properties and output code carefully before running code on your machine tool
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Replies (153)
Message 101 of 154
cncEXELY
One more user who needs human readable file names, and has an old Mitsubishi NC that only accepts Fanuc style Oxxxx operation numbers.
As for re-writing the post processor to hardcode O0001 for each program... that wouldn't work for me because my NC runs completely text free, code only, with all comments stripped out - so I do actually use unique program identifiers to confirm that the code that is loaded matches the annotated program that the operator can view on the DNC software.
So I need the facility to set unique numerical identifiers, and also Human readable file names... just like the old one did.
I'll stick with legacy until you fix it.
Message 102 of 154
Schillertb
I thought I was the only one!! I work in a Job Shop where the work is never the same. I am constantly Changing things to best optimize my programs. every modification creates a new NC program. wish there was a way to toggle that feature off.
Message 103 of 154
ltomuta
It's not just you, there others who keep posting the setup instead of posting the already created (updated) NC Program(s).
Stop doing that. 🙂
Message 104 of 154
engineguy
@Schillertb
Instead of just clicking Post Process every time have you tried selecting the existing NC Program and then Edit and Posting from there? You won`t get a new NC Program every time that way, couple of extra clicks, isn`t too hard !!! 🙂 🙂 🙂
Message 105 of 154
daniel_lyall
Right click on the setup, tool paths, or the toolpath - post prosses- name the file then hit post done.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 106 of 154
Schillertb
That was the missing link. thanks  🙂
Message 107 of 154
brandon_hanoun
Kind of off topic but as I can't seem create a post on the forums I'll ask it here.
I was wondering if the fusion 360 team could add the Fanuc Robodrill long bed machine model to stock vendor machines for machine simulation?
Message 108 of 154
stealthypride
How do I post process for shapeoko 4 I can’t seem to find the profile ?
Message 109 of 154
seth.madore
@stealthypride please refrain from resurrecting multiple threads for the same issue 😉
Seth Madore
Message 110 of 154
The tab 'nc programs' expands every time I post a program, for me that's not necessary and it annoys me that my tree get's very long that way. I love to see an option to keep it permanently closed just like the 'model' tab.
CoertHFT
Message 111 of 154
ltomuta
You are using it the wrong way. Select the operations/setups you want to post. Right click then click "Create NC Program". An NC Program gets created for you. That's what you post from now on, that NC Program. Every time you want to update the output .NC file, you run Post Process on the NC Program, not on operations/setup. This way no unneeded new NC Program is ever created. But in order to do that, the NC Programs needs to stay expanded.
Message 112 of 154
engineguy
@Anonymous
You only need a single NC Program, it should have all your Setups and Operations in it then all you need to do is click on the NC Program, right click and choose Edit, the NC Program will open and you can then select/deselect any Setup/Operations that you want to post.
That is all you need, no need to be selecting operations at the Browser Tree, if you do that then you will need to recreate the NC Program with selected Setups/Operations and if you want to re-post anything you will have to re-create it all over again 😞
Anyway, if you don`t like the way the NC Program works you can always go back to the "Legacy" Post Processing method by going to your "Preferences" and under the "Preview" tab enable the older method as shown below 🙂
Hope that has been of some help 🙂
Message 113 of 154
Thanks for your reply!
Oh alright it works like that, never used it that way 😉. I use right click on the setup and post again! I will look in to it tomorrow, see if I like it. It does look like I need to do more mouseclicks (I don't like unnecessary mouseclicks 😜) but I will find that out tomorrow.
Message 114 of 154
Less mouseclicks! Thank you! Also thanks to @ltomuta
Message 115 of 154
EdDRM
Issue with hass pre-NGC post.
file name window not allowing letters.
Also if I edit an old program it changes the file name to numbers.
Message 116 of 154
seth.madore
@EdDRM please confine your issue to one thread, rather than spread across several older threads that are not quite related to the issue you are encountering
Seth Madore
Message 117 of 154
EdDRM
Really!!!
A customer is having an issue with your product and instead of trying to
help with the issue this what you do...sit back and police the forums and
let other customers try to help out!
Message 118 of 154
seth.madore
Seth Madore
Message 119 of 154
gmitchell4DUMN
Observer
Observer
is there a way to continue to use the Legacy NC program for the post processing. I find the new system absolutely horrible to use.
Message 120 of 154
KneubaeckerS7UG4
As far as I have seen the legacy continues to be available as a "preview" feature. If you go into preferences you can turn it on
