post processing add X axis movement
xavierBCLVV
Message 1 of 10
xavierBCLVV
I'm trying to use my 4th axis A (along Y axis), the simulation is working well.
But when I'm doing the post-processing it adds an X axis movement while there is no movement on the simulation.
I'm using mach3mill for post-processing.
Replies (9)
Message 2 of 10
a.laasW8M6T
Hi
Often with 4 axis work this comes from not having the WCS located at the rotary centerline.
But without knowing how you have your file setup and whether your machine definition is configured correctly that is just a guess.
If you could share your file that would help in determining the issue.
Goto File>Export>save as .f3d/.f3z
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 10
xavierBCLVV
First, thanks for the reply.
I tried with just a cylinder but I had the same issue.
I can't join my .f3z here it says that it's not possible so i join 2 pictures and the gcode and hope it will help.
Message 4 of 10
programming2C78B
Z needs to be the center of rotation for rotary work.
put the f3z in a zip and you can upload it
Please click "Accept Solution" if what I wrote solved your issue!
Message 5 of 10
xavierBCLVV
My Z axis is the height, my rotary axis is along Y axis.
I have this machine : https://www.acctekgroup.com/fr/product/akm1325-r-cnc-router/
Message 6 of 10
programming2C78B
Thats not what youre showing! Z axis must be on center of rotation (green axis)
Message 7 of 10
a.laasW8M6T
Yes your WCS needs to be located here on center of rotation
now you get no X moves
But if you want it to correctly output A moves when the Rotary is along Y you need to edit the machine definition and change the Coordinate to A but the Orientation to around y
Andrew Laas
Message 8 of 10
xavierBCLVV
I changed it and it works.
But I don't understand why it don't work before, it was the same coordinate for X ?
Message 9 of 10
programming2C78B
it didnt work before because it was wrong.
If your C.O.R. was the top of the part, then technically the part would move in X when you rotated it.
Message 10 of 10
xavierBCLVV
Oh I see, I didn't expect this, thanks for your answers everyone
