Post proccess fails for 5 axis Haas pre-NGC
kimreeg
Message 1 of 18
kimreeg
My post processing always fails to post process using Haas pre-NGC or using Haas NGC
Replies (17)
Message 2 of 18
a.laasW8M6T
Hi
We will need more details to be able to help.
What error message do you get?
Are you using a machine in your setup?
If you can share your file that would be helpful too.
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 18
kimreeg
I keep getting this message when I try to attach my file.
Correct the highlighted errors and try again.
The attachment's rs-0102 top cap, com10 bearing v20.f3z content type (application/fusion) does not match its file extension and has been removed.
Message 4 of 18
a.laasW8M6T
Hi
You can drag and drop it into a reply or Zip the file and attach, its an unfortunate bug in the forum software
Andrew Laas
Message 5 of 18
kimreeg
I zipped it
Message 6 of 18
a.laasW8M6T
Hi
You still haven't mentioned what the error message you are getting is.
I see you have no machine selected in your setup which is generally required for posting 5 axis programs.
You can set your axis configuration in the Haas post though and it will post process fine
You will need to verify that the rotations are correct as haas' often have the axes inverted compared to normal conventions
Andrew Laas
Message 7 of 18
programming2C78B
for us its A rev, C yes.
Please click "Accept Solution" if what I wrote solved your issue!
Message 8 of 18
kimreeg
Ok, I get it. I'm a numb nuts here. I try to download the machine and I get to this.
Message 9 of 18
kimreeg
this
Message 10 of 18
kimreeg
I think I made progress, but the machine flips around when I want the A-axis to stay in one position for all the operations with the B-axis( I can't get the C-axis to change to B) changing.
Message 11 of 18
a.laasW8M6T
Hi
Machine Connector is not needed to post code, Its used for live connections for inspection probing cycles
https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-HOW-TO-WORK-WITH-MACHINE-CONNECTORS-INSPECTIO...
There is no Fusion file in that last attachment, just a step and parasolid of a vice.
Did you mean to upload your Fusion file with machine?
You STILL haven't told us what he error message you are getting is.
A screen recording of the problems you are having would go a long way to help us understand.
Andrew Laas
Message 12 of 18
kimreeg
I tried to show the error several times along with the model file that would get rejected because it wasn't zipped. I am far beyond that now because of the help from this forum.
My latest problem is that I screwed up the machine in machine builder and am trying to select a machine file that is not screwed up and it say there is a link to another machine file and can't be loaded. I don't know what to do.
Message 13 of 18
kimreeg
I fixed it by erasing documents of past machines in the machine picking page. Now it is doing something weird on the 3rd operation of flipping the platter 90 to the side?
Is there anyway to control how it decides how to position the axis'?
I want to do all the steps with the A axis positioned like the first 2 steps and just rotate the plater.
Message 14 of 18
programming2C78B
your Y axis is pointing the wrong way on ops 1,2,4. Your post will probably fix this automatically.
Message 15 of 18
kimreeg
Operations 1 and 2 work great. Operation 3 is goofy and operation 4 is super goofy.
Message 16 of 18
a.laasW8M6T
Hi
See video:
(view in My Videos)
Andrew Laas
Message 17 of 18
kimreeg
Wow. That was so helpful to this rookie. Thanks for the video. What a fantastic way to show someone their errors.
Message 18 of 18
kimreeg
I changed the B axis to rotate around the Z axis and the simulation worked perfect for the next tool also. I am on my way!!! Thanks to all the help on this forum.
